Electrolux Guardian Bagged Canister Vacuum
Problem for Electrolux Guardian Bagged Canister Vacuum
I jammed a deodorant cap into the entry hard
By subman4 on Oct 28, 2009
i jammed a deodorant cap into the entry hard plastic part of the hose. can I open that up to get it out?
Solution #1
posted on Oct 29, 2009
Not Rated)
Chemist1961
Rank: Guru  Electrolux Vacuums  Expert
Rating: 93%, 156 votes
What goes into a vac hose enters the smallest part. The handle is designed to be a small reducer to prevent some blockage so the obstruction must back out. Do not attempt to use a sharp coathanger as you could tear the inside of t the hose and do not attempt to push the cover deeper as it will wedge tight. Your best bet is to draw this item back out with another vac. Sometimes bumping,( not smashing) the side of the handle against a carpeted floor area while doing so will help dislodge the item. Failing that you will need to open the handle itself.
If you look closely on this hose there are several small screw covers which will pop out with a pin to reveal hidden screws. Once removed the handle will open like a **** shell and then slide off the hose. The handle must be carefully aligned when reinstalling and the wire covers installed last, with the handle fully in place.
If all else fails and you must use a wire coat hanger, create a small 190 degree hook at the end so there is no chance of a sharp edge cutting the hose itself if pushed to far. Post back with results or if you need more help
Was this helpful?
Yes
No
Popular Solutions for Electrolux Guardian Bagged
Questions and Unsolved Problems for Electrolux Guardian Bagged
Do you recommend Electrolux Guardian Bagged Canister Vacuum?
Answer
Answer
I know you have to remove the rubber bumpers and somehow pull the locking strips out. My problem is... (More)
Answer
Have taken out all screws on the bottom of the unit and can't get it to open. The top potion of the... (More)
Answer
any suction on vacumm cuts it off. bag is fine. nothing in hose or beater bar attachment.
Answer
Can you tell me how to change carbon brushes of my electra 1200 washing machine please?
Answer
the red light on the wand handle is on, not the green....I changed the bag, but this didn't fix the... (More)
Describe your Vacuums problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
