Starting up taking to long 3 minutes or more hoping u can help
  • 1,006 Answers
Yess we can just follow the instructions:
Go start run then type MSCONFIG.Then go to STARTUP DESABLE ALL PROGRAMS ( just don't desable antivirus)
Let me know if u got help
Please rate me as FIXYA!
Posted on Jan 02, 2008
Engine start to run rough and shot off after 3-4 minutes running
Possible solutions:
You could have water in your gas if so a $3 additive will unfreeze and eliminate this which will cause rough idling. If your carb is clean make sure to let the blower warm up for several minutes, take off the choke as it warms and it will run smoothly. Last if those dont work, adjust your carbs mixture setting screw (when the engine is warm). (and check your oil! Hope this helps.
Feb 04, 2014 | Mtd Snow Thrower 28" 357cc Ohv
How do I clean print head on epson stylus nx105 printer useing windows 7
On this printer just hold down the Stop 12_27_2012_2_42_59_pm.jpg button for 3 seconds to start a cleaning cycle. It takes about a minute on your printer.
Hope this helps
Dec 27, 2012 | Epson Stylus NX105 All-In-One Printer
How long do you boil prawns for
Depending on the size, prawns and shrimp should be cooked in a matter of minutes. Larger prawns will take a few more minutes.
You can tell when prawns and shrimp are cooked, as they will turn a pink colour.
As a guide, small - medium sized shrimp will take 3 - 4 minutes, large shrimp will take 5 - 8 minutes and jumbo shrimp or prawn will need 7 - 8 minutes cooking time.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 24, 2011 | Computers & Internet
Won't start, radio locked, security light flashing and check engine. Disconnected positive battery and connected started. While driving radio locked up again amp dropped out and air quit stopped shut off...
If your vehicle has the GM Passkey system, it is possible the security lockout has been engaged. The way to reset the Passkey system is as follows.
1.Turn the key to the ignition "on" position (but do not start the engine) and leave it in the on position for 10 minutes. After the ten minutes has passed, turn the key to the off position.
2. repeat the above step 2 more times. This will take about 30 minutes.
3.Do not attempt to start the vehicle or use any accessories while performing this reset procedure.
I hope this helps.
Sep 16, 2010 | Chevrolet Monte Carlo Cars & Trucks
Takes 45 minutes to start
Samsung will fix this for FREE, call them
May 12, 2010 | Samsung lN-T406F 40 in. LCD HDTV
"System Starting Up" message on the phone forever
I often have the same problem and haven't found the solid solution for it yet. But, for me usually helps doing this in following order:
1. restarting my router
2. unplugging the base for about 10 minutes
3. taking the batteries out for about 10 minutes
Hope it will work for you too.
Oct 01, 2009 | Philips VOIP8411B/37 IP Phone
I have a 97 volkswagen Jetta GLX that is idleing very low
there is no code......unless you're using a vag-com?
have you disconnected the battery recently? or anything of the sort. if so, you may need to align your throttle body. anyhow, disconnect the battery for 10 minutes or more. it takes at least 10 minutes for the ecu to reset, so the longer the better. now, reconnect the battery, as quickly as possible, get in and turn the key to the battery. youll hear a buzzing of sorts from the engine bay if its working. leave the key on battery for 3 minutes. the buzzing will have stopped, before 3 minutes, but after the 3 minutes, start the car. now, let it sit at idle for 3 minutes, dont touch the gas. just let it sit. after 3 minutes at idle, go for a drive and you should be all set. hope that helps.
Sep 03, 2009 | 1997 Volkswagen Jetta
1996 mazda mx3 precidia, extremely hard to start
Before you spend the time and money,get the auto choke checked.It may make the car hard to start.Basics 1st.Hope this helps
Aug 18, 2009 | 1995 Mazda MX-3
Car won't start a few minutes go by and it starts
i had same problem with my buick it turned out to be fuel pump inside of tank how fun was that repair oh joy i would replace fuel filter first and if that dont take care of it consider replacing fuel pump hope this helps good luck and have a great day.
May 01, 2009 | Chevrolet Monte Carlo Cars & Trucks
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
