Question about Toshiba Standard (CRT) Televisions
Toshiba 34" TV model 3430dxe
Picture not syncronizing for 1st 10 or so minutes. used to be only 1 or 2 minutes but has steadily increased to 10 or more.
0 characters
1 Points
Picture fades to black
Find the vertical IC and check for very small cracks on the solder joints of its pins and resolder (approx. 10 Pins). Also check in the same area for a 1 micro farad at 50 vdc capacitor that goes bad and replace it.
Dec 18, 2013 | Toshiba CX32F60 32" TV
Toshiba TV stuck in TheatreWide mode
One fo the simple answers is if you have any of the new energy saving lamps (PL Lamps) is if you have one within 10 feet of the tv, the light inhibits the ir siganl.
Turn off your lights and see.
Hope it helps
Apr 03, 2009 | Toshiba 34HF81 34" TV
Standby light flashing steadily no picture or sound
sory I didnt see the model number in on the other page. It is telling you a problem in power supply. I think yo might need to look at Q 8013 Q 8014 R 8051 Im looking at a model different model so or it could be listed as IC 8002 I dont have the same model in front of me to look at right now in my books the resistor will be real low in value 0.1 ohm usley will go open or not read on meter. Be sure to unplug tv before you open it up and look around.
Mar 01, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Toshiba tv 2151tb how do i tune in stations
Toshiba TV 2151TB Tuning
Press remote button adjacent to the picture brightness button.
The symbol of a clock appears.
Press the button again and the >>> symbol appears, this is for course tuning.
Touch the Increase Volume button and auto tuning starts.
When a station is found two green underlines appear.
Type the station number i.e.for 2 type 02, this stores the station.
Touch the Increase volume button again to find the nexr station.
Upto 39 stations can be stored.
Fine tuning of any station is achieved by pressing the tuning button until three blocks sysbol is displayed.
Use the Increase/Decrease Volume buttos to fine tune the station.
Feb 24, 2009 | Toshiba 19A26 19" TV
It gives an excellent reception but only for a while
There is a problem with the tuner section. I would first suspect poor solder connections. If resoldering the ground connections on the tuner fails to resolve the problem, a replacement can be purchased for $38.40 using part number: 8-598-594-30
Jan 05, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Try unplugging the TV for about 10 minutes and then tunung it on again. Try a factory
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
I'm assuming step 2 means hold down the power button.
Nov 27, 2008 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Toshiba 3430DXE
Model number provided is incomplete, missing leading letters.
FYI, most TV user manuals are available on factory support website
Oct 18, 2008 | Standard (CRT) Televisions
No Picture on my Toshiba television
Try hooking the tv up to the back with the right cords. Turn off 1st and replug the tv and turn back on.
Nov 26, 2007 | Toshiba 36A43 36" TV
Picture shifted and ghost image
Try using an input other than the tuner. I.e a DVD player or game system on the front inputs. If the picture looks OK on the other input, your tuner is damaged and will need replaced, if it looks bad also, try unplugging the TV for 5 minutes and then go through the setup process in the menus. If this fails seek a repair shop.
Sep 08, 2007 | Toshiba 34HF81 34" TV
Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Nov 04, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Standard (CRT) Televisions Logo
62 people viewed this question
Top Toshiba Standard (CRT) Televisions Experts
Jaime Hernandez
Are you a Toshiba Standard (CRT) Television Expert? Answer questions, earn points and help others
