WHY? MY PONTIAC CAR WHEN IS VERY COLD ITS HARD TO START ENGINE I WILL START MORE TIMES THEN HE WILL START. THE PROBLEM WHEN IS COLD TO HARD TO START, WHEN IT SUMMER EASY TO START ENGINE , WHY? WHEN IS VERY COLD TO HARD TO START MY CAR,, PLEASE HELP ME TO FIX THIS MY CAR PROBLEM , THANK YOU FOR HELP
I read the other two solutions top your problem and I have to say, some people should not give advice, because the advice they are giving is not worth anything. NOW, let me tell you what is wrong with your car. You have a defective IAC (Idle Air Control) value. The IAC value (sometimes called a cold start value) is used as a means to quickly start your car when it is cold outside. Replace the IAC (easy to do) and your problem will be solved..
Great idea so where do I find the iac on "rusty bucket"? Thanks
The IAC value (or motor as it is sometimes called) is located on your throttle body. It will be a small cylinderical looking object that has an electrical plug clipped to it. On GM engines, it is right next to the Mass Air Flow (MAF) sensor. You can either remove it and clean it throughly with carb. cleaner or you can replace it. The cost of a new IAC is anywhere from $30-$50.
i will ghange this on my 01 yugon . i also cleaned the mass air flow sensor . it may help as well .,
Change,plugs,cap&rotor,wires,change electric coil,change fuel filter
Check your battery, and see if the cca's (cold crankink amps) are up to par. How to test is, when it is cold try starting, if it starts slow shut off immediatly and put a "jump" on it. If it starts quickly...replace battery.
