Question about LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW 16x6x16x DVD-R/RW 40x24x40x CD-R/RW 5x DVD-RAM 8.4GB 4x +... (ODDWG4163O) Burner
Drive won't open
When you boot up the computer and the light flashes green I can open drive and pop in a disk, however once the green light stops flashing I can not open the disk drive anymore.
  • Shelzy0 Jan 02, 2008
    Already tried that, and unfortunately it doesn't fix it!!
  • 796 Answers
U can see a pin hole on the drive just above the open button or the green light...press the button once n poke the hole with a pin ,,,,it ll hit a soft end...continue pressing it with some force....the tray will open...
Posted on Jan 02, 2008
Flash Drive (Kingmax) cannot be read by the computer
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no
dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
Jul 06, 2012 | Electronics - Others
Tip
INSTALL WINDOWS 7 USING USB PEN DRIVE !!!!!!!!
Requirements:
*USB Flash Drive (Minimum 4GB)
*Windows 7 or Vista installation files.
Follow the below steps to create bootable Windows 7/Vista USB drive using which you can install Windows 7/Vista easily.
1. Plug-in your USB flash drive to USB port and move all the contents from USB drive to a safe location on your system.
2. Open Command Prompt with admin rights. Use any of the below methods to open Command Prompt with admin rights.
*Type cmd in Start menu search box and hit Ctrl+ Shift+ Enter.
Or
*Go to Start menu > All programs > Accessories, right click on Command Prompt and select Run as administrator.
3. You need to know about the USB drive a little bit. Type in the following commands in the command prompt:
First type DISKPART and hit enter
Next type LIST DISK command and note down the Disk number (ex: Disk 1) of your USB flash drive. In the below screenshot my Flash Drive Disk no is Disk 1.
4. Next type all the below commands one by one. Here I assume that your disk drive no is “Disk 1”.If you have Disk 2 as your USB flash drive then use Disk 2.Refer the above step to confirm it.
So below are the commands you need to type and execute one by one:
SELECT DISK 1
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don’t close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Next insert your Windows7/Vista DVD into the optical drive and check the drive letter of the DVD drive. In this guide I will assume that your DVD drive letter is “D” and USB drive letter is “H” (open my computer to know about it).
6. Maximize the minimized Command Prompt in the 4th step.Type the following command now:
D: CD BOOT and hit enter.Where “D” is your DVD drive letter.
CD BOOT and hit enter to see the below message.
7. Type another command given below to update the USB drive with BOOTMGR compatible code.
BOOTSECT.EXE /NT60 H:
Where “H” is your USB drive letter. Once you enter the above command you will see the below message.
8. Copy your Windows 7/Vista DVD contents to the USB flash drive.
9. Your USB drive is ready to boot and install Windows 7/Vista. Only thing you need to change the boot priority at the BIOS to USB from the HDD or CD ROM drive. I won’t explain it as it’s just the matter the changing the boot priority or enabling the USB boot option in the BIOS.
Note: If you are not able to boot after following this guide means you haven’t set the BIOS priority to USB. If you got any problem in following this guide feel free to ask questions by leaving comment.
on Apr 02, 2010 | Computers & Internet
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
Step by step how to use your usb flash drive?
Steps for connecting your USB Flash Drive
Step 1: Take off the cap and insert your flash key into the USB port. The USB port is usually located on your CPU tower (just below where you insert your floppy disk or CD. There will be a symbol that looks like a 'sideways cactus.' See picture.
brymz.jpegUSB symbol
Note : Some computers will have the USB port located on the back of the CPU Tower.
Step 2: Next, you can double-click on "My Computer" on your desktop or hold down the "Flag" key and the letter "E" at the same time (the "flag" key is located between the Ctrl and Alt keys on your keyboard, see picture). This will open up "My Computer".
Step 3: Once you open up "My Computer" to open your flash key, you will need to double-click on it, which at your home computer will either be the E:, F:, or G: drive.
Note:
The reason for why the drive letter might differ, is that your flash key is a "removable" storage so it assigns the next available drive letter. Also, once you insert your flash key in again, the F: drive will change its name to PKBACK, or Removable Disk, or even to the brand name of the flash key such as "Kingston".
Steps for disconnecting your USB Flash Key
Step 1: Make sure that you have saved the documents you have been working on and then close them by clicking on the big red X in the upper right-hand corner.
Step 2: Once everything is closed, click once on the little green arrow at the bottom right of the task bar (see picture).
A message in a box will appear saying "Safely Remove Hardware", or "Safely remove USB Mass Storage Device". Click once on that message.
Step 3: It should now be safe for you to take out your Flash key.
Note : If you want to be certain it is safe, go into "my computer" and check to make sure that the "removable disk" and drive letter your flash key was assigned have disappeared.
Note: If the green arrow still appears, click on it again and it should disappear. If a message appears saying "The device 'Generic Volume' cannot be stopped right now. Try stopping the device later", you will want to make sure that all of your programs or documents on your flash key are closed out.
If you re-try it and the message still appears, push Ctrl + Alt + Delete on your keyboard and then shutdown your computer. You can then take out your flash key or you can re-boot the computer and follow the same process above. You should then be able to remove it safely.
Flash drives are a very useful storage device because of their reliability and memory capacity. Learning how to use them may take a little experience, but once understood the flash drive can assist you in many ways with not only your data files, but using software that the host computer does not have. Also remember that a flash key is not indestructible, so you will want to use more than one physical location to store your data, such as your computer's hard drive, etc.
Sep 13, 2011 | Computers & Internet
Alarm is going off. When I open it and look at the 6 hard drives inside the top one doesn't have a green light on, instead it is flashing orange and green. How do I fix this?
Remove the drive and clone it to a new one or use the raid software to rebuild to a new one.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Acer Altos G510 Server
My hard drive has just stopped being recognised by my computers.The computer knows when i plug in but the hard drive does not show up in my computer. The green lights flashes internittently but not...
I had the same problem, This is what I did to fix. get a recent copy of a live disc from linux, run and boot from live disc, I used puppy linux as is small and can run from ram completely, after puppy is up and running you can mount the drive your trying to get photos off, find the photos and copy the not move, to either a portable flash drive or to the c drive acceses through puppy mounting utility, after copying all the photos you require then formatt the drive in linux puppy to ntfs, after this is done shut down puppy remove puppy disc and restart copmuter back to windows and the drive should be accessable once again, I hope this helps
Feb 13, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
How do you save files on a sandisk cruzer flash drive?
Insert the cruzer into the usb port. You should see a message pop up and say new hardware found and then flash off. It may also say usb memory or storage device or even recognize it as the cruzor. This recognition process is fairly quick say 5-10 seconds. After that the computer knows what the cruzer is and its ready for use.
The cruzer is now seen as another drive or storage drive on your computer. Your hard drive is usually C , the CD/DVD would be D drive and the cruzer would be seen as E. If you are in a program and want to save to the cruzer you open the file/save and you should see E drive or Cruzer if not click on my computer and look for it there. Once you find it just click on it and then hit save/ok. Thats all there is to using one. Once you know how to find it as a save option or a loading option then you just treat it like a hard drive.
Once you get it sorted out you will use it a lot. They are very handy.
Jun 01, 2010 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
How to boot laptop from usb flash disk
When u just turn on your laptop go to bios settings.....in bios settings change the boot priority to USB flashdrive....save and restart before you restart connect your flash drive to ur laptop......it will ask boot from flash drive press any key....n contiune...hope this helps
Mar 11, 2010 | Computers & Internet
Flash Disk
Insert new disk for drive F:
and press ENTER when ready...
The type of the file system is RAW.
Please use the /FS switch to specify the file system
you wish to use on this volume.
Apr 03, 2008 | Dell Inspiron 6400 Notebook
Can't read, burn cds
have you tried different cds? or just 1 same cd?
Oct 19, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
240 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
