Question about HP Pavilion dv6000z Notebook
Starting up taking to lond
When i turn my computer on its take about 3 or more minutes to start up hoping u can solve this problem for me
    Scholar:
  • 131 Answers
The logon process depends on what all programs are starting up with windows, if you have installed plenty of softwares that start up with OS then it takes some time as all the start up process has to be loaded into memory.
I you have any unwanted softwares that start up during the OS start up, Uninstall them, this will speed up the startup process.
Kindly rate me as fixya
Posted on Jan 10, 2008
How long does it take for the heat to turn on
Heat in your car or house? Either way it will take a bit to warm up. If after 10 mnts or so if it's still not hot, then you may need to have it looked at
Jan 04, 2015 | Dryers
Renault scenic problems 2002 53 plate 1.6 takes about 3-4 minutes to start when cold
yea sounds like a bad starter, in the cold it will not make complete contact when soleniod triggered.. this is due to worn contacts inside, when warm it makes a better contact, if you replace the starter this will solve your problem, also have the battery and alternator tested
Dec 01, 2013 | Cars & Trucks
I go to the store. Turn truck off. Go inside and come back outside and the truck won't start. Wait about 20 minutes and truck starts right up. This has happend 3 times in the last week. This morni
usually this is a cam position sensor I have found this problem many times by replaceing the camshaft position sensor I believe this will solve your problem if this is helpful please leave good feedback
Apr 13, 2013 | Ford F-150 Cars & Trucks
My 2007 gmc sierra quit and has no fuel pressure
A lot of GM vehicles will start for a few seconds then turn off, it's due to the VAT System. Vehicle Anti-theft System. The most common procedure to relearn the key to the BMC is to: 1.Put key in turn to the ON position, security light should come on and stay on, wait 10 minutes, light should go out.
2. Turn Key off, wait five seconds.
3. Repeat steps 1 and 2; 3 times, it will take you 30 minutes to do this, but I've have multiple vehicles that this solved the problem. It's most common when changing wiring harnesses, BCM's, and steering columns.
4. After the third cycle of turning the key on and off for the appropriate amount of time, you should be able to crank it over and it will stay running.
Keep in mind, this is if you're fighting a computer problem,not general maintenance. Hope this helps!
May 11, 2012 | 2007 GMC Sierra 1500
My sony vaio turns off by itself and dosen't turn on
i think you can format your pc and repair the power botton
i hope i can solve your problem
Aug 25, 2009 | Computers & Internet
B4 turn key start immed-now need hold key lond time to start
Sounds like a bad battery connection, either on the battery, or the starter or engine ground, or just a poor battery.
Aug 07, 2009 | Chrysler Cirrus Cars & Trucks
When i try to start the car it wont turnover an it keeps blinking security on the dashboard
Your key has a computer chip in it that tells the computer that the person who owns the car is trying to start it. Sometimes the key will lose its memory and the car computer thinks your a thief with the wrong key. You may have to have a new key made from a code the dealer can aquire from the VIN number I believe.
Jun 27, 2009 | 2001 Pontiac Grand Am SE
Trying to reset theft system
Can try doing a  relearn process, it is pretty simple and will take 30 minutes, if it'll work for you at all since your problem doesn't sound like a computer issue.
30-Minute Learn Procedure
1. Turn on the ignition, with the engine OFF.
2. Attempt to start the engine, then release the key to ON; the vehicle will not start.
3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF.
4. Turn OFF the ignition switch, and wait 5 seconds.
5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes.
The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK.
Important:
Turn the Ignition Switch OFF.
The vehicle learns the Passlock Sensor Data Code and/or password on
the next ignition switch transition from OFF to CRANK. You must turn the ignition
OFF before attempting to start the vehicle.
6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code
and/or password.
7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100
ignition cycles.
Without a scan tool you may have momentary starter interruptions while history clears itself.
Good luck and hope this help's. keep me posted if you need other ways to disable the passive lock system
Jun 03, 2009 | 2003 Chevrolet Malibu
89 thunderbird - 3.8 Car dies
i had this problem on my 88 t-bird 3.8L. not exactly sure of the cause but to remedy mine... it seems the computer was not telling the fuel pump that the car was running. so the fuel pump would quit pumping. run a wire from your battery to the positive line going to the fuel pump (temporary). if this solves the problem (and you don't mind solving it this way) make the wire run clean and hook it to a switch so you can turn it on when you wanna drive. this is not the way a dealership would fix it but its also not gonna cost you more than you probably have invested in your car. hope this helps
Feb 17, 2009 | 1989 Ford Thunderbird
Tomtom go 300
before you start take out sd card. 1 turn tomtom upside down. 2 see reset button? 3 use paper clip to press (press for 15secs) 4 now turn on tomtom (hold power button for approx 5secs. 5 re insert sd card. after a few minutes you should have signal. hope this solves your problem.
Mar 19, 2008 | Tomtom GO 300 GPS Receiver
HP Pavilion dv6000z Notebook Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
