Jenn-Air JGS8750 Gas Kitchen Range
Problem with Jenn Air Gas Range???
posted by michelle26 on Jan 02, 2008
Hi I have a problem with my Jenn Air Gas Range. Since moving in to our house we cleaned our range and it has started to click. The range won't ignite? I can see blue light flashing instead of the flame. Can anyone help me out before I call for service? Thanks
Michelle
Comment posted on Jan 02, 2008
Hi, thanks for replying so fast! I'm talking about the burners, they click non stop?
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
tech17
Rank:Guru Guru
Rating: 88%, 1149 votes
are you talking about the burners or the oven reply with model num and dont rate me till we are finished
i have a service bulliten on that maybe are all the burners clicking or just one and by clean you mean slelf clean or you washed and i need the correct model off the serial plate is it jgs8750 and doer it light when you turn it on
Rating Locked! (?) michelle26 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Problem with Jenn Air Gas Range???:
I don't want to Accept this solution
Best Solution
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The back left burner dosen't uness it's on high to med heat...once i turn to med-low it started clicking. The back right works on any temp setting. The two front burners won't even ignite,jsut blue sparking and clicking. I am cooking on the back right one, it's the only one that works on high med and low.
I washed the range, around the burners and just the normal cleaning. The model number is JGS8750.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Can you Help with these Kitchen Ranges problems?
how do I convert this stove from propane to natural gas
When we run the oven self-clean, the oven interior...
When I press "clean" key, it beeps twice, but...
Just came home and I think the power went out while I was...
other burners make a clicking sound when only one burner...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Kitchen Range Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
