Question about Dryers
Dryer heats up but isn't drying properly
I have a Kenmore dryer...four years old...it is heating up, but isn't drying things like it used to. It gets very hot in the dryer...but clothes are still very damp after an hour of drying. I'm not drying any more clothes in one load than I used to. And, I sort of smell a "heat" smell inside of the dryer. Not sure if this makes sense.
Any help would be appreciated.
Thank you.
  • chris97394 Jan 02, 2008
    Hi. Thanks for the information. I checked the vent outside and felt air coming out. To test out the dryer I removed the vent from the back of the dryer and tried drying a load that way. First, let me say that the airflow coming out of the back of the dryer is really strong and gets hot. But, the sheets I had in the dryer weren't drying so well at all. When I opened up the dryer I smelled inside and I got that "heat" smell again. That smell just doesn't seem right. So, I stopped drying because I didn't want anything to overheat.
    This is a Kenmore dryer, model #110.64212200...although I don't think all of those numbers are the model number...but that is what it says on the tag in the dryer. It is an electric dryer by the way.
    Thank you so much for helping me!
    Chris
    Thank you very much. It is very kind of you to help. I meant to tell you that the lint screen is on the top.
    Again, I appreciate your help.
    (I'm in Oregon...other side of the country and much earlier)
    President:
  • 1,314 Answers
Yes it does something is blocking your vent either its all coiled up behind the drier or something i need to ask a few questions go out side and look at where your drier vent has a hood make sure nothing is blocking it from opening it has a little round door on it ive seen some that have little plastic screens on them that gets clogged the screen is there to keep critters from building nests in the vent line then get a flash light and look over the back to see if the vents folded over mashed etc to find out if its a vent problem take your vent loose dry a load and see if it goes back to normal if all that's ok get back to me and we will clean the drier i need to know if your lint screen is on top or in door and your model #
Posted on Jan 02, 2008
  • robert samples Jan 02, 2008
    its late where i am chattanooga tn so ill respond tommrow well get it got to what it aint to know what it is
    chris email me b4829@yahoo.com need to send you a image
Sears kenmore mod. no.11058282998 electric dryer that gets warm at first but takes two hours to dry anything
Posted on Jan 24, 2009
I have a kenmore 417 stacked washer and dryer that works but the dryer is slow to dry and the washer makes a squealing noise. what can i do to fix both?
Hello there Brian and welcome to fixya
Slow drying is a fairly common issue with dryers that are a few years old the most commmon problems is due to the following
Please check each one of these very close ok
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician. Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jan 18, 2012 | Kenmore 98702 Stacked Washer/Dryer
My kenmore is 21 years old it is still tumbling but has lost its heat to dry
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
May 24, 2011 | Kenmore Dryers
Kenmore dryer...model # 1108262101 clothes not getting dry...normal dries better than perm press but still not as good as before....where do I begin? Thanks, Mary
Hi lkyldy31...
Your dryer is acting like it has a Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Apr 22, 2011 | Kenmore Dryers
KENMORE DRYER MODEL# 86880100 SERIAL#M81937120, WHEN ON THERE IS NO HEAT FOR DRYING. THE DRYER SPINS AND MORE DRY FUNCTION HAS NO HEAT,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 12, 2011 | Kenmore Dryers
My kenmore dryer does not have heat it is two years old
heatman101
Feb 06, 2011 | Kenmore Dryers
My dryer isn`t get hot. What should i do? kenmore-400. I live in Pembroke Pines. Florida
heatman101
Dec 18, 2010 | Kenmore 400 6943 Dryer
My kenmore elite dryer is only 1 year old and does not seem to get hot and takes long time to dry clothes
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Dec 12, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer is not generating heat to dry clothes. The machine is less than 4 years old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 01, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore Electri Dryer is humming while drying.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.hope this help you out sincerely D.Jones
Jun 08, 2010 | Kenmore 64672 Electric Dryer
Kenmore elite gas dryer is not drying clothes but the dryer is running no warm air?
Hi, Do make a check of these:
  • Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
  • Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
  • Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Apr 17, 2010 | Kenmore Dryers
Dryers Logo
660 people viewed this question
Top Dryers Experts
Marvin
Marvin
