Slide Projectors
Generic problem for all Slide Projectors
Enfocus 8405 dlp projector
posted by brojohn on Jan 02, 2008
blinks red, but the fan doesn't come
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 19, 2008
Not Rated (0)
Jake121774
Rank:Master Master
Rating: 86%, 16 votes
You may find that it is a simple issue of the lamp running over the max life, i.e. 2000 to 3000 hours, in which case you would need to replace the lamp. Sometimes you may be able to "fool" the projector by pressing both of the volume keys while powering up. Also, when you power down the projector and try to restart before the lamp goes through the full cool-down cycle, this same issue will occur. In the end you may need to send the projector for service as it may be a much greater issue.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on enfocus 8405 dlp projector:
I don't want to Accept this solution
Can you Help with these Slide Projectors problems?
Vivitar V5000AF 35mm 100 Slides Rotary...
is there a timing sequence for the gear set on the vivitar...
Kodak Carousel 4600 35mm 140 Slides Rotary...
I think I pushed the reverse button while the projector...
Rollei 66 Dual P 35mm / Medium Format Slide...
Rubber belt needed in Canberra, Australia. How can I get...
Elmo Projectors HV-8000SX Slide Projector
Image does not display on wall (screen).
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Find Slide Projector Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
