Sanyo DP42746 42 in. Plasma Television
Problem for Sanyo DP42746 42 in. Plasma Television
I got Problem with Sanyo my DP42746 42 in. Plasma
By propoolspeci on Oct 28, 2009
i got Problem with Sanyo my DP42746 42 in. Plasma Television and is a simple just no image and no sound
Solution #1
posted on Oct 28, 2009
Not Rated)
rylee_smith
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 1044 votes
Hi
Thanks for using FixYa. If the TV isn't turning itself on then the fault protection circuit has detected a fault and has turned down the TV. You'll need to check various things to find an answer which part is bad. Please check these---
1. Check for signal cables at the back and also try unplugging the TV for 8-10 hours to reset it.
2. Swollen /bulged capacitors on the power supply board-- This happens due to overheating of capacitors.
3. If the capacitors are fine then you'll need to check for connectors on all the boards and also the fans if they are working fine.
4. Make sure the lamp connections are fine and ballast is not burnt.
Note-- Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition.
Try to reset the TV by unplugging it for 8-10 hours.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Popular Solutions for Sanyo DP42746 42 in. Plasma
Questions and Unsolved Problems for Sanyo DP42746 42 in. Plasma
Do you recommend Sanyo DP42746 42 in. Plasma Television?
Answer
Answer
Can't get TV to come on. The green light at the bottom comes on but nothing happens no sound no... (More)
Answer
the picture is black and white now thanks to 17 month old inquisitive little boy. cannot figure out... (More)
Answer
we just bought our sanyo tv 50 inch. When we turned it on and went through the channel set up the TV... (More)
Answer
what is the code to program a rcr660 remote control?
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , PA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
