I have a Sharp AL 1631 copier. I am not receiving any errors but my copies come out blank. I have tried unplugging it and restart without luck. I have replaced the toner and still blank copies. Any other ideas??
When you replace the toner cartridge, you should also clean the Corona wire. This is done by sliding the cleaner Tab back and forth several times. The toner relies on a good connection to tranfer toner to the page.
We have a canon np6551 copier that was given to us but when it is turned on it warms up and says...
(More)
We have a canon np6551 copier that was given to us but when it is turned on it warms up and says ready to copy but when you touch the screen or try to set number of copies or push start nothing happens.
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant...
(More)
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant connection (only 1) in back of tv-vcr unit and the yellow and white connections in frt of unit are connected via a cable with r-y-w to converter box and y-w to frt of tv unit. At the advance record screen..channel 3 is showing in the selection box, if you insert a different channel it will not record that channel/program. Are there any converter companies that had the foresight to know that there are hundreds of tv-vcr combos still in use? I understand the mechanics for a stand alone vcr and I know how to manually record on the combo..but I want to be able to preset and for more than one channel and recording times. Thanx
