Question about Dryers
Hoover 5030D Wall Bracket
Hi, I have a Hoover 5030D Tumble Dryer. It is the model that doesn't have wall brackets, I need to put it on a wall. How do I or where can get a wall bracket to solve the problem? Cheers Gary
SOURCE: I have a wall bracket on the laundry but hjow do I get the dryer on to the bracket
Is the wall dryer bracket, the correct one to fit your hover
Posted on May 28, 2009
0 characters
1 Points
Westinghouse dryer LD505E is to be mounted on a brick wall ,what size rawlplugs & screws are needed .I bought the wall bracket mounting kit
that unit does not have wall mounting information its user manual
or a wall mount bracket supplied with that dryer
its a 5KG dryer by the looks of it
thats means its load a with 5kgs of wet clothes on the floor
suggest to me its no meant to be wall mounted
wall mount kit might be say suit most dryers
you have to go by common sense
use bigger mountings and fixings that you think it needs
has to hold up on the wall
this much weight
the all up wet weight of clothes
the dryer dry weight empty
and steady any vibration with the rotation on full load
into wood walls depends on the thickness of wood
if into dry wall ...need to hit the wall studs centre
I would not try it
if going into brick concrete ...hammer drill in and . ranset bolts
Sep 16, 2016 | Dryers
Roper gas dryer wont tumble
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Leave the drum in the machine. Now, directly in front of the motor on the floor of the dryer you will see two slots. This is where the idler pulley will go. You'll notice on the pulley at the bottom of the bracket a piece of metal sticks downward. This will sit in the slot closest to the dryer wall, and the end of the bracket will slide into the other. You'll want to slide the end in first. Now with the pulley in place take the belt and put it around the drum tread side down. To hook the belt around the motor pulley you'll have to pull the idler pulley towards closest dryer wall and place the belt around the motor pulley. Slowly release the idler pulley and thats it. Put it together and your done.
Jun 03, 2012 | Roper Dryers
Hello, i have a hoover dryer, model 5030D, secondhand, it is just been purchased my us. we put on our first load on and the machine stopped within 15minutes. we noticed then that the machine was...
Hi, if I remember correctly this model originally came with 2 faceplates so the controls can still be easily accessed, when the dryer was installed upside down on a wall. Most dryers can be run upside down, or even on their side as I done in the past with my Hoover 5030D, so the problem would lie elsewhere.
Dec 26, 2010 | Hoover Dryers
I am looking for a wall bracket to suit a Hoover dryer Model Apollo 100' Where can I purchase it?
From any electrolux outle. Look up Electrolux and phone them. Cheers Tony
Sep 11, 2010 | Dryers
Is it possible to mount the unit upside down on wall brackets, and of course, the dryer still operates satisfactorily? As there does not appear to have pressed openings on the rear panel for bracket...
Hi Don.
All appliances must be installed, used, and also transported and stored with the top side up.
If the dryer is turned upside down the weight of the drum, motor and other parts will not be sustained anymore by the rollers and other structural parts located inside the appliance.
The dryer will start, but it will break down after a short usage.
There are also other safety issues involved.
The dryer cannot be installed upside down.
Feb 26, 2010 | Hoover Dryers
Hang Hoover dryer on wall, where to buy brackets?
yes you can. go try any hardwear shop local to you. if you cant find one go to
Nov 27, 2009 | Hoover Dryers
Hanging Hoover Apollo Deluxe dryer unit from the wall
you will need to get a wall mount bracket. I found a couple on ebay for about $30.
Sep 30, 2009 | Hoover Dryers
Hoover 5010D dryer
There should be two rectangular holes about 2mm wide and 10-12mm long. There is a wall mount bracket [D470] which you install against the wall and then the hardest part is getting the dryer on the bracket.
Obviously when installing the bracket make sure that the wall and the screws can hold at least 30kgs.
Jul 18, 2009 | Hoover Dryers
May 28, 2009 | Dryers
Hoover 5050ed clothes dryer/tumble dryer
If the dryer hasn't been mounted before, you'll need to punch the blank slots through. At the bottom of the dryer (because you wall mount it up-side-down, so these slots will then be at the top), you'll see a vertical hole in one layer of the metal on the back to each side. Knock these through to reveal the holes where the bracket can go in. You'll also want to replace the control panel decal with the wall mount one that has all the controls up the correct way when wall mounted.
Jun 04, 2008 | Dryers
Dryers Logo
611 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
