My iphone was low on power when i looked at it in the morning by midday when i looked it had turned off
so i went and got the charger however now it will not charge ---- or even turn on in any form
in fact anything i do i cannot get a response from it --- ive tried a number of usb cables so it couldnt be the cable
can somone help
thx a lot,
Comments:
Nov 09, 2009
- hi 3five5,
thanks a lot for the reply,
it took me a couple of days to get hold of my wall charger,
anyways plugged it in overnight - still no sign of life at all from it,
ive tried holding down the buttons hundreds of times,
its a 3gs (32g) phone and is only a month or 2 old - has a good few apps installed (jailbroken, unlocked etc..)
what can i do now??? - i figure the solutions will get a bit more extreme from here
thanks a lot,
Have you tried plugging it into a wall socket? That's the first thing to try - if no response still you should leave it plugged in to a wall socket overnight. Sometimes they just need a large prod up the backside!
If it still won't respond try a soft reset (hold home and power buttons together for 15 seconds or so (do this while it's connected to power). If you still have no joy there are a few other courses of action but I suggest you try those first & let me know if you still have no response from it!
after I reset to factory settings, The phone restarted and slide to unlock does not work. This is a...
(More)
after I reset to factory settings, The phone restarted and slide to unlock does not work. This is a phone I bought two days a go. Please help. I tried the volume buttom as described with no success
how can i send a sms message on my iphone to all my contacts (350) at the same time... without...
(More)
HOW CAN I SEND A SMS MESSAGE ON MY IPHONE TO ALL MY CONTACTS (350) AT THE SAME TIME... WITHOUT SENDING 10 BY 10
sim card wont work in i phone says 3 didgit pin is needed, and its not the normal pin as in with the...
(More)
sim card wont work in i phone says 3 didgit pin is needed, and its not the normal pin as in with the old phone
