Question about Presto 04820 PopLite Popcorn Maker
As its warming up, kernals fly everywhere...why??
Do you warm it up, then add kernals? No instructions were included.
  • 145 Answers
You are supposed to add them after the unit is warm, generally you can add a few kernals and when they all pop out you can dump in the rest.
Posted on Feb 12, 2008
  • 77 Answers
You just put them in and wait til it is done
Posted on Feb 11, 2008
6ya staff
SOURCE:
I have a'98 Volvo S40 2.0 non turbo, recently it sputter's and idles rough for sometimes 5- 20seconds then suddenly idles smooth. It only run's smooth if allowed to warm up for 5minutes including...
You may have an old engine oil, why don't you have your car service and change oil and oil filter as well. Then if the problem still appears, then that's the time to start tracing where the problem really starts.
Jun 08, 2018 | Volvo S40 Cars & Trucks
Piaggio fly 50 4t
Re-set the idle adjustment screw on carb? Also check fuel / air filter.
Mar 22, 2014 | 2012 Piaggio Fly 50 4V
Utilitech TM-029 wall timer: I've installed the
Do not run any timer warm... replace with switch, and/or buy another timer.
Copy following link to identify timer and download instructions:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer is rated 15 amp 1875 watts.
Safe maximum is always 80% rating plate: is 12 amp and 1440 watts.
Add up total watts on circuit.
Add a comment and say what you discover.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 29, 2013 | Hardware & Accessories
My 92 toyota camry has power and all but it shifts hard wat could b the issue
Probably dirty transmission fluid and filter...you can use the ****** flush, or change the fluid and filter, or try the least costly...add one bottle of Lucas Oil transmission stabilizer fluid...(no not drain anthing) follow the instructions...warm motor, warm ****** etc. add the complete bottle...this works to restore the seals and shift points...All this of course assuming your motor is tuned and running smoothly...(clean air filter etc.) Hope this helps.
May 02, 2012 | 1992 Toyota Camry V6
Purchased Durabrand Rice Cooker model HRC 18G working fine Is there a User manual for this cooker? All that is needed is ratio of water to rice including plain long grain and Basmati rice for 1 - 4...
Instructions quoted from the Durabrand Rice Cooker model HRC 18G manual...... 1 cup of uncooked rice rice will make about 2 cups of cooked rice. Add rice to the inner pot. Maximum four cups uncooked rice for the model. Many varieties of rice can be used including basmati, wild rice, arborio risotto, saffron rice and long grain rice. Whole grains, such as barley can also be prepared with the rice cooker, follow instructions on the package.
For every cup (160ml) of raw rice, add 1-1/2cups of water. For stickier rice add slightly more water, for fluffier rice use slightly less water.
When your rice is cooked, the cooker will automatically switch to the warm function and the yellow warm light will turn on. The cooker will stay in the warm function untill is disconnected from the wall outlet. The cooker will keep the rice warm 158F - 212F
Hope this helps, its quoted right out of the manual I have for my cooker
Jul 27, 2009 | Kitchen Ranges
Cuisinart popcorn popper directions
If you are using the Cuisinart pop corn poppper, don't use olive oil. Use vegetable oil. Two teaspoons is enough with 1/3 cup of premium kernels. That is it. Turn on the machine and wait til it stops popping. I LOVE my new pop corn popper. I will not do the hot air one again. I always had kernels flying all over my kitchen and popped popcorn everywhere, The Cuisinart popper is the best....
Apr 10, 2009 | Cuisinart PartyPop Maker Popcorn Maker
Heater constanly blowing warm air
Very common problem. Heater control clips break and must be replaced. I found a lot of info on the web including instructions and pictures. Clips are cheap at www.944online.com. They aldo have the instructions and pics.
Good luck
Jul 11, 2008 | 1990 Porsche 944
Presto 04820 PopLite Popcorn Maker Logo
206 people viewed this question
Top Presto Kitchen Appliances - Others Experts
Paul Bade
john h
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
