Question about Sony STR-DE835 Receiver
Hook up problems
I just bought a sony STR-DE835 5.1 channel reciever and the full system. i got all speakers working fine but the sub i got, got just wire ends not RCA plug ins and all thats on the reciever is for the RCA ins, how can i get this system working
  • 579 Answers
Either cut an rca cable and splice it to the speaker wires (not easy because the rca cable is coax type or buy rca ends from radio shack and do a little soldering
Posted on Jan 02, 2008
Subwoofer onkyo
A lot of these systems have options for switching off speakers and subs. You should look up the speaker settings options of the Sony. If you have the manual see what it says about connecting an active sub.
Aug 04, 2013 | Sony STR-DE997 7.1 Channels Receiver
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
I have a sony STR-DH510 receiver and the speaker set that goes with the DAV-BC 150. i hooked up the speakers but i couldn't get the sub to output any sound. is there anything i can do to get it to work?
Hello ,you will want to go into the setup mode on the remote and make sure the subwoofer is turned on,it might be turned off .You can view the setings right on the front of the reciever as your scrolling thru speaker setting options.
Feb 08, 2011 | Sony STR-DH500 A/V Receiver
I just bought a new Sony STR-DH510 reciever, I connected a sub woofer and 2 surround sound speakers to it and it worked perfectly. The next day I go to turn it on and it will turn on for about 30 seconds...
Problem is in the amplifier output stage...there is probably a shorted component...the short could have come from a bad speaker..or the speaker wires getting touched together while it was could return to store if it is new and get a new one...maybe it was a return and accidentally got put back into stock
Jan 20, 2011 | Sony STR-DG510 Receiver
My dad has a 7.1 home theater speaker system, and I've toyed with the STR-DE897 receiver to get all of the channels to work, but I can only get the 5.1 to work, any idea how to get the 7.1 to work?
It needs to be encoded on the media such as a DVD movie or CD - it should say 7.1 surround recorded. I'm assuming you have all seven speakers and sub-woofer hooked up, too?
Dec 31, 2010 | Sony STR-DE897 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
I've problem getting any Sub sound from Sony STR DB840. The sub is ok and I've correct setting on my reciever with sub enabled. When performing tone test... I can hear sound from all connected speaker...
make sure sub is working .Power it up , remove sub RCA jacks from receiver .Gently tap on RCA with fingers.You should here a hum when touched .You can also try audio from TAPE REC OUT .If you dont get audio .Check setting at sub .If it working okay check setting at receiver and or sub level at receiver
Jul 20, 2009 | Sony STR-DB840 Receiver
Bought some replacement speakers and the reciever seems to get ver hot!
Hello! Yes, you need to worry when a Sony gets hot!! You probably have replaced factory 8 ohm speakers with 4 ohm speakers. Look on the back of your new speakers and see what they are. Then look at the rear of your receiver by the speaker terminals and there will be a sentence like "8 Ohm minimum per channel". If your Sony says " 8 ohms " you need to use 8 ohm speakers.
Also, are you a using low level signal ( audio out ) to drive your sub or are you using high level ( speaker line )??? I'd use low level. Good luck!!
Oct 09, 2008 | Sony STR-DE635 Receiver
Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Oct 30, 2007 | Audio Players & Recorders
Sony STR-DE835 Receiver Logo
137 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
