Question about Philips GoGear HDD1830 MP3 Player
Cannot save songs
I try to save songs on my 2GB phillips gogear. i tried to save it but it never comes
  • 8,596 Answers
Use Windows Media Player to transfer songs instead of your music service. Also, b sure to install the installation CD for the GoGear before using - it has important drivers that you may need for proper fucntioning of the device.
-Tha Mp3 Doctor
Posted on Feb 11, 2008
Whenever i try to play a song on my phillips gogear vibe mp3 player it sais "file format not supported' and they are mp3 files.What gives?
"File format not supported" means that the song that you've downloaded into your MP3 player is NOT an .MP3 file format. For each MP3 player have their own supported file formats. You need to check the manual of your MP3 player to see what are the supported sound file formats (i.e. .mp3, .wma, .mp4). Then check the file format of the songs that are saved in your player.
If the songs are supported but you're still getting the error message, try to delete all the songs and then download the songs again and save it into your player. If the same problem occur, then it may need a firmware upgrade or reformat.
Thank you and good luck!
Oct 31, 2010 | Philips GOGEAR SA6045 MP3 Player
I have a Phillips GoGear (Marietta GA 30006-0026) 2GB Mp3 player but i have lost the installation disc software. How do i go about downloading this?
Aug 06, 2010 | Philips GoGear SA3125/37 MP3 Player
How can you remove songs from the Phillips GoGear 2gb MP3 player so that you can add new ones? Its nearing capacity- and I'd like to drop some songs and add different ones- but can't figure out how to do...
download your new songs plug in the mp3 to the pc.... a box will popup select open file select the songs you dont want and delete them one by one leave that open find your songs and drag them across
Feb 22, 2010 | Audio Players & Recorders
I am trying to use Limewire to stream or download music onto my MP# with no success. Everytime I try to move the files to the Phillip's window, it states that it cannot read this files. What am I su
the downloaded songs are saved in a folder in your pc/laptop...copy songs from there to your my music folder and then sync your player with that...should work fine :)
May 19, 2009 | Philips GOGEAR SA6045 MP3 Player
Phillips SA3125 2GB "shuffle all" problem.
I would go ahead and try the firmware update to see if it resolves your issue - for the firmware update to work, you have to get the most recent version of the Philips Device Manager from Philips website. It will erase all the songs in the GoGear, so make sure you have them backed up.
-Tha Mp3 doctor
Jan 18, 2009 | Philips GoGear SA3125/37 MP3 Player
I had already saved some songs on my gogear 2gb, and when i plugged it in to delete those and add some more, i accidentally deleted the music file from the mp3 player.
Unfortunately, deleting that music file is irreversible - you can try running the Repair in Philips Device Manager, but it most likely will not work. Call Philips and see if you are in warranty.
-Tha Mp3 Doctor
Dec 30, 2008 | Philips GOGEAR SA6045 MP3 Player
Delete songs from MP3
Try when plugging it in go to the start button.
Click 'Computer' and there should be an icon saying 'Phillips'.
Click and go into the songs and right click to delete.
Not sure if this'll help you out.
-AJ
Nov 24, 2008 | Philips GOGEAR SA6045 MP3 Player
Nothing works
Does it say Philips and then go dark? If so, try pushing the reset button. Mine did this yesterday, because I did a complete erase. I had to push the reset a couple of times, then it started working again. I'm back in business, and listening to my songs as I type this.
Is your battery charged fully? Did you let it charge via your computer?
Jun 29, 2008 | Philips GoGear SA3125/37 MP3 Player
Mp3 phillips
There are a few possible answers:
1)Start simple - disconnect the GoGear from the computer - let it update - then reconnect it to the computer; if this fails, restart your computer and try syncing again
2)You need a firmware upgrade to make the device compatible with your computer: just open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website; click on the update tab
3) The songs have Digital Rights Management (DRM) protection.Try re-downloading the songs without DRM protection.
4) The songs are in a format not recognized by the GoGear. The GoGear, for instance, will not take iTunes files b/c they are AAC format. With MP3 files, the player supports 32 –320kbps. With WMA: 5-192kbps with sampling rate 8.0kHz up to 44.1kHz. Right click the song file, and select "Save As", and then change the format of the song file. Or, redonwload, in the above-said format.
-Tha Mp3 Doctor
Jan 20, 2008 | Philips GOGEAR SA6045 MP3 Player
Trying to play my music which I have transfered from CD to my phillips MP3 player and it says File format not supported.
The device itself is not faulty. This is Microsoft's1.gif fault, not Philips'. Some of the songs may have Digital Rights Management (DRM) encoding that the SA6025 will not support. You can right click on the trouble music file, select "Properties," and select the License or Digital Right tab - look for the msg: This file is not copyright protected. Find out if the songs that CAN'T be transferred have this message. If so, then click on acquire digital rights (or some variant of that phrase). If the files tha CAN'T be transferred DO have Digital rights protection, then you must save the files in a different format that is stripped of DRM encryption.
-Tha Mp3 Doctor
Dec 30, 2007 | Philips GoGear SA261 MP3 Player
Philips GoGear HDD1830 MP3 Player Logo
52 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
