Question about Polaroid FLM-323B Television
CHANNEL DISPLAY HD signal is great on antenna. Problem encountered is off the antenna channel 8-1 displays as 9-1 / RF9-1. This is this way with several chanels off the antenna. Any ideas/suggestions ?
I had the same thing happening. 20.1 was 19.1 as well as 12.1, 12.2, and 12.3 were 38.1-38.3. In the last couple of weeks my tv has freaked out and died. I'm just passed one year so I think I'm screwed. I looked and it has corrosion on both boards. That might explain why the logic circuitry didn't work right. Maybe not. As a computer builder though I know corrosion is a bad thing.
Posted on Feb 07, 2008
What causes pixelation only on digital 9 TV and there subsidiaries
Pixellation is a weak and noisy signal coming in. Digital HD needs a good signal at the antenna socket on the back of the TV. You need to have good quality quad shield coax cable down from the antenna, and preferably crimped F-connectors at each plug and socket. You may even need a new digital antenna if you are making do with an older analogue one.
Your other stations will also improve.
Dec 26, 2015 | Televison & Video
How do I receive HD Channels on a Techwood 22884 HD Digital
Ensure your antenna is properly connected. If you are using a cable or satellite provider, ensure your subscriber equipment is HD capable. If HD channel signals are not available (antenna, SAT or cable), then the television cannot display them.
Have you tried another HD television (if available) in the same configuration, and does it work? More information about your installation with manufacturer and models will help.
Feb 03, 2015 | Televison & Video
Toshiba 46HM95 wont display 720p from dtv antenna other tv works
lets start with the easiest first.does your tv in the menu option offer an input output source like 720p or 480p?on my set i can change to any format.maybe yours does too.let me know and we go from there.
Mar 04, 2010 | Toshiba 42H81 42" Rear Projection...
HDTV unable to get HD Channels w/ Antenna
The problem could be your antenna. Many people will buy small indoor tv antennas and wonder why they're not getting the signal that they want or the channels that they expect. Its not your fault. Digital signal is in two formats: UHF AND VHF. Some antennas only receive UHF. But many of the low band channels are VHF, so 1) you need an antenna that will receive those signals and 2) you need to know how and where to install that antenna and 3) you need to know if you need a signal amplifier depending on your coaxial cable length and number of connections. I recommend visiting dennys antenna service (no I don't work there and I have never purchased anything from that website. He just has an excellent informational article with a great deal of "how to" on his pages.). http://www.dennysantennaservice.com/2029710.html This should be of great help to you. Happy viewing =)
Dec 26, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
"No Signal" on channel 9
Appears you are getting a weak signal at the channel 9 frequency. If you are using a signal splitter, try replacing it with an amplified unit since splitters always do the deed but they can and will reduce signal strength significantly.
Also remember that digital signals are not like the older analog ones that they replace. They are not subject to ghosting but are weaker and susceptible to all sorts of interference such as a leaf, rain, etc. Your antenna is good.
You also might try raising the antenna. The higher it is the better it works. (use some wire to further support additional height) Why do you think transmitters are so tall?!?!?
Mar 22, 2017 | Vizio VW32L 32 in. LCD HDTV
With the new HD transfer. We just have atenna...we just bought a HD TV. Is there a way of connecting the DVD Recorder so I can watch one channel and tape another with this new system
A lot of your question depends on your DVD recorder, but there IS a way to connect them so you can watch one channel and record another one.
First - if you have an HD compatible DVD recorder (one that will allow you to select channel 8, 8.1, 8.2, etc) then you could simply split your antenna signal BEFORE the TV or DVD recorder. Then you can select one channel to watch on your TV while selecting and recording a different channel on the DVD recorder. If your DVD recorder is connected to your TV's Video Input, you should be able to monitor DVD recorder's activity by selecting the "Video Input" on your TV.
If you DON'T have an HD DVD recorder, then you will need to get a converter box to put between the Antenna signal and the DVD recorder. You can then set the converter box to the channel you want and the DVD recorder can be set to record it.
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I cannot select Channel 10
What kind of antenna is used. Outdoor antenna or indoor antenna. The main board only detect the signal with certain level, if the signal strength is not enough, it will pass by. Since the change of signal from analog to digital this problem got more depending on your location. You need to use a booster-antenna to over come this problem.
Jun 03, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
I purchased a SANYO-DP46848 42"HDTV. I have a Cable box and my cable provider (Time Warner Cable) provides free HD Channels. However.... I CANNOT PICKUP ANY HD CHANNELS ON THE NEW TV. WHY???...
I just got the same exact one, when it searches automatically the first time it doesn't look for digital channels. go to Menu>manual channel search>cable. it will look for all possible signals and will take forever probably. the free digital channels will take several seconds to switch channel to channel, but they're there! They will show up on your screen as "DC 91-2" or similar. you can switch back to regular cable channels with the input button, you just cycle through all the inputs. hope that helps.
May 18, 2008 | Televison & Video
How to see local channels in HD with a traditional antenna?
If your set does not have an ATSC tuner, for HD, then you need to be using a suitably equipped STB.
Your satellite STB - box - should take in OTA channels and display them as part of its normal operation, tho. It takes in the antenna signal from your roof antenna and displays the HD version of your OTA channels, if it is an HD STB, along with the HD channels it gets from the satellite overhead.
Mr Bob
Dec 19, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Polaroid FLM-323B Television Logo
54 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
