Question about Standard Horizon CP-1000C GPS Receiver
Standard horizon cp 1000 gps
Who makes a thru hull underwater camera for the cp 1000 gps ? thanks
3 Suggested Answers
  • 4090 Answers
SOURCE: standard horizon 155c not acquiring signal
If the signal is good statement seems to imply that it is working, perhaps this is my misinterpretation of what you mean by this.
Signal refers to the abi;ity to connect to satellites
4 are requied for triangulation.
If the unit is fully charged and not connecting , then it is quite possible that the unit has a damaged SIIRF chip or whatever chip was used in your model to acquire satellite connection. The cost of repair is costly, it means total replacement of the M/Board.
Never start car with the unit connected into DC car power, spikes will damage the chip
Posted on Jun 30, 2009
  • 296 Answers
SOURCE: IS THERE A DOWNLOAD FOR A MANUAL FOR A Standard
Hi, You can download it from below link:- http://www.standardhorizon.com/downloadFile.cfm?FileID=1451&FileCatID=85&FileName=CP150.pdf&FileContentType=application/pdf
Thanks! mannu_rakesh
Posted on Aug 17, 2009
Screen says c card invalid
Your best bet here would be to either head for a marine chandlery that handles these C-Cards and have them plug yours into one of their chartplotters or a vessel nearby that uses the same cartridge.
If your card works on theirs chartplotter, the problem lies within your CP150. If they get the same fault displayed as you do on your unit, for some reason the Card has a fault.
Hope this helps.
May 02, 2010 | Standard Horizon CP-150 WAAS GPS Receiver
Tip
What do you mean by hold the bottom right corner of the screen. It isnt a touch...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Jul 25, 2008 | Garmin StreetPilot C330 GPS Receiver
It does not aquire satelites, a new aerial has been fitted and everything else seems ok.
Check voltage at the plotter antenna outlet. It should be at least 5 Volts .if not you have a blown internal fuse
Jan 03, 2010 | Standard Horizon CP-150 WAAS GPS Receiver
I dont have C-kard.
Hi
I dont have have C kard . I ask the application of type of card -where I can
buy with software .
Stanley
Aug 22, 2009 | Standard Horizon CP-150 WAAS GPS Receiver
C card invalid
I don't have C-card .what shall I do ?when I can by this card?
Aug 12, 2009 | Standard Horizon CP-150 WAAS GPS Receiver
Standard horizon 155c not acquiring signal
Jun 30, 2009 | Standard Horizon CP-150 WAAS GPS Receiver
Help
supposedly not you only need a card for more detailed maps
Nov 15, 2008 | Standard Horizon CP-150 WAAS GPS Receiver
CP 160
I can not put the name of the points on my gps chart 160
May 26, 2008 | Standard Horizon CP160 GPS Receiver
Orientation
It is not likely that there is a software error that could cause that problem so I'm going to cover some basic information first. Forgive me if I'm covering stuff you already know. There are 3 chart orientation modes, North Up, Heads Up, and Course Up. North Up you already know! In Heads Up mode, the chart will only orient heads up when the boat is moving. Unless you have an electronic compass interfaced to your GPS it has no way of knowing which way you are facing. Once you start to move, it compares your new position to the old position to determine which way is heads up. If you are not moving, the map defaults to North Up even if you are in heads up mode. Course Up mode is commonly mistaken for Heads Up. In Course Up mode, the GPS orients the top of the screen toward a waypoint that you have told the GPS to go to. If no waypoint is selected, the GPS will default to North Up orientation. So I guess what I'm saying is, make sure the boat is moving, and make sure you're not in course up mode (unless you want to be).
In the unlikely event that there is a software error causing this problem, it can easily be fixed by getting an update from Standard Horizon. You can either get them to send you an update chip, or download it online and copy it to a blank C Map card. When you turn the GPS there will be a message on the opening screen that identifies you software version. Get that information before you call Standard.
Feb 13, 2008 | Standard Horizon CP-1000C GPS Receiver
Power cord
I called standard horizon myself and bought the power cord for $25. The # 714-827-7600
Nov 12, 2007 | Standard Horizon CP150 GPS Receiver
Standard Horizon CP-1000C GPS Receiver Logo
163 people viewed this question
Top Standard Horizon GPS Experts
Steve
Steve
Mike Mullett
Mike Mullett
Level 1 Expert
Are you a Standard Horizon GPS Expert? Answer questions, earn points and help others
