Question about Microsoft Windows Vista Ultimate Edition
FRONT PAGE i CANNOT INSTALL MY FRONT PAGE, DOES MICROSS HAVE A PATCH OR SOLUTION?
  • Partysachs Mar 14, 2008
    I just cannot load it at all. From what I hear it will be forever impossible and my only recourse is to use another web design software or strip Vista off my new computer and re-install XP...Any ideas welcome.
    Patty
  • 3 Answers
Microsoft Front Page 2003 is not for use with Vista. I do not think they have an upgrade or patch you can download. I do think they have a thing called Microsoft Expressions that works with Vista. I don't know if it does the same things as Front Page or not. Hope this helps.
Posted on Jan 02, 2008
Iwant to downelod front page?
Posted on Oct 29, 2008
Emperor RotMK patch will not install
Maybe the suggestions on this page will help.. I don't have the game and just used a Google search to find a reference to the patch:
https://www.gamepressure.com/download.asp?ID=58680
Jan 13, 2018 | Computers & Internet
Canon printer scaning error 255,0,0 how it solve?
There is a recommended patch to install if you are having issues scanning in Windows 10. Let's perform the following steps to download and install the scanning patch:
1. Click HERE to launch the download and driver page. Your operating system should automatically be detected.
2. Under the "Drivers" tab, you will need to download and install the file Windows 32-bit & 64-bit] Patch for Network Scan, USB Scan.
3. Attempt a scan at this point
Nov 27, 2017 | Canon Office Equipment & Supplies
War Front Turning Point in Windows 7 cannot find the original cd
download War Front Turning Point patch .this patch can running on any system include win7.This patch did not need original CD just Copy over the cracked executable located in the Crack dir on the DVD to
the \Run dir of your installation directory.
You can download from patch.ali213.net/showpatch/5004.html
This is chinese web site
Patch is 10.8MB. I'm not sure can mail if somebody need it.
Apr 05, 2010 | CDV Software War Front: Turning Point for...
1990 cutlass ceira how do you replace drivers door side mirror
Outside Mirrors REMOVAL & INSTALLATION Standard
  1. Remove the door trim panel and detach the inner panel water deflector. With the glass in the down position, pull out the front portion of the glass run weatherstrip. Fig. 1: Unfasten the attaching nuts from the mirror base studs, then remove the mirror 8c45877.gif
  1. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler, then rotate retainer rearward.
  2. Remove the noise control patch to gain access to the screw at the belt, then remove the screw.
  3. Remove the filler attaching screws at the top front of the window frame, then remove the mirror and filler from the door.
  4. Remove the attaching nuts from the mirror base studs, then remove the mirror. To install:
  5. Be sure that the mirror gasket is aligned.
  6. Replace the mirror and filler on the door. Install the filler attaching screws at the top front of the window frame. Attach the nuts to the mirror studs and tighten.
  7. Install the screw at the belt, then insert the noise control patch.
  8. Insert the retainer, then install the attaching bolts and screws to the front glass run channel lower retainer to filler.
  9. Replace the front portion of the glass run weatherstrip, insert the inner panel water deflector, then reinstall the door trim panel.
Manual Remote
  1. Remove the mirror remote control escutcheons and door trim panel. Detach the inner panel water deflector. NOTE: Right side remote mirror may require detaching part of the instrument panel.
  2. With the glass in the down position, pull out the front portion of the glass run weatherstrip.
  3. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler and rotate retainer rearward.
  4. Remove the noise control patch to gain access to the 0.3 in. (7mm) screw at the belt and remove the screw.
  5. Remove the filler attaching screws at the top front of the window frame.
  6. Remove the mirror base with mirror and cable assembly from the door.
  7. Remove the mirror to filler attaching nuts and remove the mirror and cable from filler. To install:
  8. Be sure cable is routed around front glass run channel retainer and installed to clip.
  9. Install and connect the cable to the filler.
  10. Attach the filler nuts to the mirror, then tighten to 72 inch lbs. (8 Nm).
  11. Install the mirror base with the mirror and cable assembly to the door.
  12. Insert the filler attaching screws to the top of the window frame, then install the screw to the belt.
  13. Secure the noise control patch.
  14. Attach the bolts and screws to the front of the glass run channel lower retainer and filler.
  15. Install the glass run weatherstrip.
  16. Attach the inner panel water deflector, door trim panel and mirror remote control escutcheon.
Electric Remote
  1. Disconnect the negative battery cable.
  2. Remove the mirror remote control escutcheons and door trim panel. Detach the inner panel water deflector and the electrical connector for the mirror. NOTE: Right side remote mirror may require detaching part of the instrument panel.
  3. With the glass in the down position, pull out the front portion of the glass run weatherstrip.
  4. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler and rotate retainer rearward.
  5. Remove the noise control patch to gain access to the 0.3 in. (7mm) screw at the belt and remove the screw.
  6. Remove the filler attaching screws at the top front of the window frame.
  7. Remove the mirror base with mirror and electric connector from the door.
  8. Remove the mirror to filler attaching nuts and remove the mirror and electric wire from filler.
  9. To install, reverse Steps 1 through 6. Be sure electric wire is routed around front glass run channel retainer and installed to the clip. Tighten the nuts to 72 inch lbs. (8 Nm).
  10. Connect the negative battery cable, then reset the clock, radio and any other accessories if required.
Aug 25, 2009 | 1990 Oldsmobile Cutlass Ciera
My printer is hooked up ok I assume
first i would want to know if you use vista as an os? i would only be guessing without more info. if you use vista they have a patch to keep the drivers ffrom uninstalling themselves. you can get this patch at hp.com. i would down load this patch to your desktop uninstall all hp software the reinstall it. immediately when the install is done double click the patch file. i had this problem with a 7410
May 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
I want to install AVG virus protection, but cannot do it because my computer needs Vista patch KB959247. Cannot find the patch that I need in order to continue.
You can download this patch from Microsoft via the Grisoft Website if you look at this page link I have provided you need to select FAQ number 1177 then choose the download according to your OS ie 32bit or 64bit
LINK - http://www.avg.co.uk/uk.faq.num-1066#faq_1066
Aug 11, 2008 | Computers & Internet
I have problems using software. I was told there's something called a "patch". what is it?
A Patch is an update to the software, which updates the program. Usually it fixes bugs or adds new features. Some programs have an option to "Check for updates" on the About option.
Others require you to go to the manufacturer site, and download the patch from an Updates (or Downloads) page. They usually give you instructions on how to install it on the same page.
The general idea is to save the patch to your computer, then double-click on it. That usually starts the install.
If you need more specific instructions, post a follow up here with the software name and we can give you more help.
Here's a tip - when you post questions here, try to be a bit more specific about your issue - what software, what problems. You'll get a faster answer that way.
Good Luck
Jul 25, 2008 | Computers & Internet
Vista Patch
Simple, most unlikely solution: Try to download patch from microsoft website and install it.
Other Solution: Go to trained professional, (geeksquad or firedog), they will install it more simply and correctly.
Installation of software by them is probably like 30 bucks.
Mar 19, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
