I just bought a 2010 Nissan Sentra, and it had an ipod hookup thing in the glove compartment, with a cord that connects to an ipd, so you can control through the radio. Only problem is I have a SZune, not Ipod, so the cable doesn't fit in the zune port. How do I use the Zune without having to use the auxiliary jack option??
SOURCE: Zune 30 gig Brown Overheating
well? This sounds like you have the wrong cord. It is too short and so it gets power every now and then and then after doing this for a wile it gets over heated. The power going into the Zune is changing so fast that it is causing the plug to burn-up inside itself!
I wound try to call about a warranty and then if that doesn't help then get a new cord!!!
SOURCE: ZUNE 30GB Zune Music... Problem
There are two ways to format an Mp3 player - one on the computer
itself, and one in Windows Media Player. Both methods will end up
erasing all the songs on the player, but the player will be "good as
new" after that. Sometimes reformatting in this manner will override
the player's native formatting and cause problems - this can be
reversed in most cases by updating the player's firmware. Firmware
upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or
FAT32. - Connect player to computer, double-click my computer, right
click on icon of mp3 player and select format. This only applies to
Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media
Player. Click on the Sync tab. Pull down the drop down menu underneath
the Sync tab by moving your cursor over the Sync tab and left clicking
on the little black arrow underneath the Sync tab. Highlight "name of
Mp3 player here 1GB" (wording may vary slightly), and then select
"Format." - this should erase everything.
-Tha Mp3 Doctor
SOURCE: my zune is not detected by my laptop or zune software.
try to wiggle the zune cord but not to hard
SOURCE: How can I sync music onto my zune 120GB without using zune softwa
Easy:
Use Windows Media Player. It should see your Zune and you should be able to sync it that way. If not, then try hitting your "My Computer" button on your desktop or your shortcut menu. You should see your Zune on that window once your computer sees it. Then open your "My Music" folder in a separate window, drag and drop the music you want in your Zune, and you should be good to go!
