Home | Palm | Tungsten E2 (Multilingual) Handheld | Calibration gets stu...
Palm Tungsten E2  Handheld
Problem for Palm Tungsten E2 (Multilingual) Handheld
Calibration gets stuck in a loop
By albangould_b on Oct 28, 2009
calibration of the touchscreen gets stuck in a loop. I keep tapping in the centre of the target but it just keeps jumping from corner to centre to corner
Solution #1
posted on Oct 28, 2009
Not Rated)
NinaE
Rank: Guru
Rating: 86%, 309 votes
Hello.
Do a soft or hard reset (pin in back of PDA; pin in back of PDA and front silver button simultaneously).
If not, what worked for me is to take the PDA apart, if you are comfortable. There are 4 screws in the back. Remove them. With a knife, flathead screwdriver or other flat object, pry open the back. A few plastic pieces may fall out, tho. Note where they connect. Disconnect and then reconnect the power adapter. Put the plastic pieces and the back of the PDA together. The back should snap in place. Insert the 4 screws. Should work OK, again. Use this method if the adapter is not charging very well and the soft / hard reset doesn't work. I've had to perform this many times. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Palm Tungsten E2 Handheld
Questions and Unsolved Problems for Palm Tungsten E2 Handheld
Do you recommend Palm Tungsten E2 (Multilingual) Handheld?
Answer
Answer
i can't access my list of pdf files. I need to delete some files but the application jumps from the... (More)
Answer
I cannot get my hotsynnc to connect to the internet. I have a palmone tungstenE2. I replaced the... (More)
Answer
Palm Tungsten E2 will not turn on. I charged the battery and I pushed the reset button on the back.... (More)
Answer
So I have a nokia and whenever I turn it off and turn it back on it always takes forever to load up... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Palm Tungsten E2 Handheld:
Top PDA Experts
Rank: Guru Guru
Solutions: 552
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
