Question about Transcend T.sonic 610 MP3 Player
Head fone hi! my tsonic headphone is not working! could you pls suggest me of some head phones that gives same output as that of the original one! also pls provide me the technical specification of Tsonic head phone so that i can match it with other head fones.. kindly help
  • 8,596 Answers
Manual has specs on the back and is avail at:
http://www.transcendusa.com/Support/DLCenter/index.asp
if you try another set fo headphones,a nd they also do not work, then there is an internal hardware problem with the Tsonic, and it will have to be replaced.
Posted on May 23, 2008
Connect sony headphones to sanyo television
If the tv does not have A head phone jack on it, No type of head phones will woprk on it.
Aug 30, 2012 | Sony Audio Players & Recorders
Hi plz help me i am using IBM r51 laptop which has all drivers but not able to get sound of it. but when i connect a headphone i can get sound of it. but my laptops speakers r working as i tested mt...
ibm sound card is not faulty, because you are getting sound with your head phone. The head phone jack have two functions 1. to give output to head phone 2. to disconnect internal speakers when you plug in head phone.
The jack for headphone in normal position not give connectivity to internal speakers.
SOLUTION : REPLACE THE HEADPHONE JACK.
I think it will help you.
Sep 15, 2011 | IBM ThinkPad Soundcard
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
I just received for my birthday, a RCA 900 MHz headphones. Followed the instructions but cannot get it to work. I tried to install it on a Hitasha TV. Can you help me?
  • "Connect the RCAheadphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) RCA pilot lamp should flicker in parallel to voice coming from TV
  • RCA headphone should have 2 different rotary adjustment on it..one "Volume" and the second "Frequency" adjustment
  • while TV talking , adjust slowly the "frequency rotary dial" to catch the headphone transmitter coming from RCA headphone base,when you catch it you will hear the voice of TV,(sometimes fine adjustment makes it better ) than adjust volume properly..
  • .After this pls do not touch Frequency dial any more..Just Turn it on ,and Volume adjustment ..Thats it..
  • After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs work independently from the TV's master volume control..
Jun 30, 2011 | RCA Audio Players & Recorders
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Nov 25, 2008 | Denon AVR588 Receiver
Headphone Jack
Unfortunately these units are designed to output to either the speakers or the headphones. There are devices available on the market that will take the output from the tape-out jacks and transmit it to a wireless headphone. I would suggest that you investigate this. That would also eliminate any wires stretching from the equipment.
Search the web for "assistive listening" devices.
Dan
May 13, 2008 | Onkyo TX-SR605 Receiver
Sim lock
you need to put back the original sim card in the phone and do a master reset.....in the phone settings.....
menu/settings/intial setup/master reset - 000000 security default code
Jan 06, 2008 | Nokia 1600 Cellular Phone
Transcend head fone!
Jan 02, 2008 | Transcend T.sonic 610 MP3 Player
Transcend T.sonic 610 MP3 Player Logo
169 people viewed this question
Top Transcend Audio Players & Recorders Experts
Gyula Lacz
aliasger yq
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
