I am having a problem with my Handspring Visor as I cannot hotsync the device. Every attempt to hotsync ends up with an error message "AlarmMgr.c,Line 365, disable underflow" and I am prompted to reset. Even after reset I am still unable to hotsync the device. Can you help me please to resolve this matter. Thank you.
Do a hard reset on your pda, that will get rid of the syncing problem, hard reset instructions :
to perform a hard reset: 1.Hold down the power button on the front panel of the handheld. 2.While holding down the power button, use an unfolded paper clip (or similar object without a sharp tip) to gently press the reset button. 3.Release the power button. 4.When a message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, do one of the following: Press the top scroll button on the front panel of your handheld to complete the hard reset and display the Digitizer screen. Press any other button to perform a soft reset. Note: With a hard reset, the current date and time are retained. Formats Preferences and other settings are restored to their factory default settings.
If you have important data on the pda and you do not back up it regularly you should purchase a back up program or learn to use the hot sync to back up your content so that you do not loose your files in the future.
my visor wont turn on, nothings appearing on the screen, its still new and i hardly use it. it was...
(More)
my visor wont turn on, nothings appearing on the screen, its still new and i hardly use it. it was working before i put it aside, i tried soft resetting, hard resetting, power down resetting, nothing, my batteries are new, and i cant think of anything else to do, can you guys help me? i would appreciate it a lot..... thanks
I used to have the palm pilot but never really liked using it... but I always loved the desktop...
(More)
I used to have the palm pilot but never really liked using it... but I always loved the desktop version that was used to synchronize the info. It was so simple to use as an address book. I still have the installation CD and I still use it on my Windows Vista believe it or not. Is there a way that I can update the software to the newest version without buying the actual hand held palm pilot? The installation CD color is green and it says 1999-2000 Handspring, Inc - part no. 50-0115-00. I don't mind paying for the software if I have to. Thank you for your help! Terri
how to save contacts and calendar as outlook files
Trying to transfer contacts and coa;ander from...
(More)
Trying to transfer contacts and coa;ander from Palm to Outlook
The hard keys of my Handspring Deluxe (8mb, black, Palm OS 3.1) started to fail some time ago, at...
(More)
The hard keys of my Handspring Deluxe (8mb, black, Palm OS 3.1) started to fail some time ago, at the beginning it happened sometimes the datebook button didnīt work, now is not only datebook button but up and down button too.
up and down hardkeys are very important. Iīve searched hard for an application to reassign hardkeys but the closer ones to my problem remap only a damaged power button not the other hard keys, other apps deal with remapping soft keys to launch applications, not the functions of the up and down hard keys.
Please, if someone knows a program to reassign those hard keys up and down functions to other soft keys even a stylus solution, or a DIY repair (because I donīt want to send it to Palm) please let me know, thank you
Juan
