Polaroid i1032 Digital Camera Logo
Posted on Oct 28, 2009
The picture comes out distorted as if the screen is shattered can this be fixed?
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
9helpful
2answers
Sony cybershot Dsc-t33 view screen is distorted
This is known issue of ccd imager chip failure in Sony DSC-T33 camera and ccd imager chip will be replaced to get correct live view to take pictures.
Required ccd imager chip is available with Part Store for $52
Let me know if you have additional question.
Thanks.
When i put a picture as a wallpaper it get distorted because it fixes to the screen proportions!!! how can i fix this problem?
edit the picture in pc and crop it to appropriate proportions so that it does not get distorted
2answers
Picture distortion
I have a vs 8087 good working condition
$700 you pick up Chicago area
[email protected]
1800FP image distorted
this is a little known porblem Dell has. Dell is not tell anybody.
I don't know if this is going to fix the monitor for the long haul, but it should help in the mean time.
grable the frame of monitor with both hands, apply some pressure, not too much (you will break the glass). change location and do the same thing. the screen will come back at certain location, when you apply the pressure to the frame. this is because some connection inside of the frame is coming loose with time.
good luck
if that doesn't fix the proble, please post.
Shatter
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Distorted picture
tv has red & blue converge problem,tried to fix it with remote by multipoint lining the t,s up didn,t help
SAMSUNG SP-P4251 DISTORTED PICTURE AND THEN SCREEN GOES BLUE
Wow same here but mine is red I know its because of the plasma bulb is wearing out and for my fix is $1000 but I didn't do want to go on so I tried to change the color settings and tried RGB to all 0 and it became fine. Well at least you have a cool blue screen, mine is red.
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
