Canon iP100 Portable Printer
Problem for Canon iP100 Portable Printer
I need to change the printer cartridge. Help.
By trimiewd on Oct 28, 2009
Solution #1
posted on Oct 28, 2009
Not Rated)
rajak2009
Rank: Wiz
Rating: 84%, 237 votes
Sir,
1) switch the printer on
2) lift up the scanning/copy platen - put you fingers underneath the LED display and lift it
3) in a couple of seconds the cartridges will move over to the left, where you can pull them out and replace them.
Thanks Good Luck
Was this helpful?
Yes
No
Solution #2
Not Rated)
erroreater
Rank: Wiz  Computer Hardware  Expert
Rating: 79%, 19 votes
k its very easy plz click on help tab on printer properties or contact u r printer's website there u can see the all steps with pic or yoc can take help with youtube.com with full video how u change and normaly cartridge change with new one with just put move or pull
Was this helpful?
Yes
No
Popular Solutions for Canon iP100 Portable Printer
Questions and Unsolved Problems for Canon iP100 Portable Printer
Do you recommend Canon iP100 Portable Printer ?
Answer
Answer
Trying to set up Canon iP100 so that we can access it across a network.
Answer
Canon iP100 printer will not print PDF's or documents from InDesign. In fact, when printing this... (More)
Answer
Canon iP100 always has a paper jam whenever I try to print
Answer
Printer won't work. Green and yellow light flash on off alternately. Turning it on off on doesn't... (More)
Answer
I have a Canon EOS 40D camera and want to know if the iP100 is a compatible printer for it...?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon iP100 Portable Printer :
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
