Question about Sanyo EM-Z2001S Microwave Oven
Today is the day my microwave stopped working
Yesterday it worked just fine
just now i tried it... all it does after i enter the cook time and power, etc, press start... all it does is click.
i unplugged and started over... to no avail.
suggestions?
  • katrinac1 Jan 17, 2008
    I have had my microwave a year now and when i use it, it stops completely and powers off. sometimes it does this after 10 seconds. sometimes after 2 seconds but it always stops. i switch outlets and still the same problem. it works as if it has a shortage or something. when i replug it up, it works for about 2 seconds and does the same thing....what is wrong????help someone....
  • 579 Answers
Magnatron is suspect.
Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there)
Should be getting 120Vac when it goes to cook cycle.
Don't touch the other (high voltage) side of this transformer.
If the power is there, you are looking at replacing the magnatron.
Could also be the high voltage capacitor or diode.
Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Posted on Jan 02, 2008
6ya staff
SOURCE:
Tip
DANGER WARNING! Potential Hazard if your microwave was working and now doesn't...
If you have this model microwave and it was working fine, then one day it stopped heating items placed inside there are a handful of different issues that could be the problem. In my case it was intermittent, over a period of a few days it would sometimes work (heat) and sometimes not. NO MATTER if this is what your's is doing or if it stopped heating all together. If you decide to let it dry out, or not use it for a while to see if it was a one time occurrence, or whatever the reason, the first time you put something in and probably for the next 10 times at least (this assumes it starts to work again), make sure you are right there with it while it is cooking. Don't assume you can put something in, go do something and come back when the timer is beeping. There is a chance (as this happened to me) that your food inside will CATCH FIRE! Normal food item placed inside, no metal, nothing different than the numerous times before when this had been cooked but when we smelled smoke we came running. Fortunately it started and finished inside the microwave but that's not a guarantee, it could spread. Play it safe. Never had a problem like this before and never heard of a microwave cooking something until it caught on fire (especially since the time entered for the cook was 30 seconds) but it did.
on Sep 23, 2013 | GE JVM1850SMSS Microwave Oven
Works fine before unplugging, stops working when plugged in again
Westinghouse WST3504 User Instructions Before Calling For Service
YOU CAN OFTEN CORRECT OPERATING PROBLEMS YOURSELF
AND TRY THE SOLUTIONS LISTED FOR EACH PROBLEM
Note: If the Microwave Oven still does not work properly, please contact Service and Repair
located on Warranty page. 19
BEFORE CALLING FOR SERVICE Possible Causes
• Is the power cord plugged in?
• Is the door closed?
• Is the cooking time set?
Feb 01, 2018 | Westinghouse WST3504 Microwave Oven
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
LG 1925 Microwave suddenly stopped cooking, other functions work fine!
What you said about the the clock leads me to suggest that you first unplug it for a few minutes then plug it back in. It may just need a good reset. If you don't have your owner's manual you can download one here: http://www.lge.com/support/manual.jsp The mention of odor concerns me. It may just be a bit of food or grease on the waveguide cover, which is a small sheet or panel on the wall or ceiling of the cooking cavity, but it may indicate the failure of a part in the high voltage section. You may have an intermittent door switch. You can see some of my other responses for info on how to get our important text file that helps you diagnose and repair door switches and gives important safety tips.
Dec 10, 2006 | LG LMV1925 Microwave Oven
Sanyo EM-Z2001S Microwave Oven Logo
125 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
tony denham
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
