Question about Toshiba 36AF62 36" TV
Toshiba telivisions picture brightens
Does anyone know why my picture brightens and returns to normal shade of black. It kind of flickers between normal and then brightens. IF I play with the plug or cables coming in it would turn to normal black but after awhile brightens again. Thanks
  • 373 Answers
It has a bad solder connection inside the set. Requires qualified individual to find the connection and resolder it.
Posted on Jan 02, 2008
Why is my picture darker than normal
It may be the backlighting has been readjusted by someone other yourself. Whenever you go on battery, I'm sure you've seen the screen darken a bit. This is the backlighting being turned down to save battery life. There is usually a blue function "fn" key that allows the user to brighten or darken the display. Look at the blue icons in the F1-F12 keys. The one to brighten the display looks light a sun and the one to darken the display looks a full moon eclipsed. Press and hold the fn key and tap the desired function key to brighten or darken the display.
Jan 13, 2012 | Toshiba Computers & Internet
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
Toshiba 40H80 Rear Projection TV flickering & blacked out
try converence board going out on your unit usally about 300 bucks to fix ok thx nick
Feb 08, 2008 | Toshiba 40H80 40" Rear Projection...
Picture went black during viewing and won't return
its looks ur screen is DEATH.........as u only have the set for 18 months i assume u have no warrentie left'
may go in touch with TOSHIBA and tell them ur problem u have......
but it looks to me u need a new screen,,,,,or may a service will solve ur problem,,,,,it may cost u .......but may cheaper as a new screen
Nov 20, 2009 | Televison & Video
When I turn my Toshiba laptop on,it's black
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 26, 2009 | Toshiba Computers & Internet
Dim display on Toshiba Satellite 4090XDVD notebook
The backlight CCFL lamp provides the lighting for the LCD screen. If you have already adjusted the brightness to the max. setting and it is still dim, it means the CCFL lamp is is nearly worn out. To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp. Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 18, 2009 | Toshiba Satellite 4090XDVD Notebook
Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Dec 14, 2008 | Toshiba REGZA 32WLG66 32 in. Television
Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Oct 09, 2008 | Toshiba TP50G60 50" Rear Projection...
3d effect
Shading with a black cartridge will be different than shading with a color cartridge. Replace the black cartridge with a color, and things should return to normal.
On the re-fill cartridge, replace it with a new OEM cartridge, and if that works, the refil is defective.
Dec 31, 2007 | Lexmark JetPrinter Z12 color InkJet
Flickering tv screen when playing playstation games.
I don't think it's a configuration problem at all. I do think that the set is not adjusting to the correct format. Most Stores have 30 day return policy. If it's over 30 days then they may not take it back. If you bought it online, then, the return may be difficult. If the return is not possible, then, contact Toshiba online and find a local Toshiba authorized servicer in your area. Hope this helps.
Mar 18, 2007 | Toshiba 15VL33B 15 in. LCD Television
Toshiba 36AF62 36" TV Logo
63 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
