Question about Samsung SpinPoint SP8004H 80 GB Hard Drive
Hard drive replacement
Attempting to replace a hardd rive and install Windows XP. Old hard drive wasvSamsung SP8004h hard drive. New one doesn't have to be equal in brand or even storage. 40 GB or higher is fine. Need a new hard drive that connects directly to the motherboard (40 pin connection) not SATA that connects through a RAID PCI slot interface. What brand and model would have the same interface and connector as the Samsung SP8004h (40 pin connection)
    Problem Solver:
  • 11 Answers
SATA drives are the latest hard drives available nowadays. You could try going online and checking other sites that could still have an IDE hard available for sale.
Posted on Jan 02, 2008
What drivers are need for clean windows xp install on sony vaio pcg-k37?
This model Sony came installed with a 80Gb hard disk and a 40 Gb
Do a clean Windows install on this old hard drive -
Boot up with the Windows installation CD
install Windows on the hard drive
Delete the existing Windows partition
Create a new partition
Format the new partition (full format not Quick format)
Continue installing Windows.
Mar 24, 2012 | Sony PCGK37 Notebook
Install 2nd Hard Drive with different connectors and different OS.
yes you can use either sata power or molex(4 pin) plug to power your new SATA hard drive but not both at the same time.
Mar 19, 2012 | Samsung SpinPoint SP8004H 80 GB Hard Drive
I would like to install windows xp on the hp hdx9150. But Sata disks are not recognised. So i find a driver for that, i can give to the systeme with touh F6 , wind cd-rom windows xp bigin to install
According to your problem first check the hard drive status and make sure that it is ok. If it doesn't detect in bios setup then you can change the cable of the hard drive. Also make sure that the DVD Rom working fine. If the hard drive doesn't detect while you begin setup then clear the bios first. Then reset the bios properly. You may need a firmware update also. If you can not continue the setup then break the partition of the hard drive. You can use partition break up software, like partition magic etc also. If it doesn't solve your problem then you may need to replace the hard drive. To check the hard drive status you can try with another OS installation. Best of luck.
Aug 05, 2011 | Seagate 60GB 5400RPM SATA 100 – ST96812AS...
I cant install windows xp in my ibm m51 8141 dekstop when i boot system to cd rom then after few minits the system show the error "windows ini file cant loaded" i have 3 windows cds but i try the...
You may have to Reformat your hard drive first. The current hard rive may have a bad operating system on it or one that is newer than XP. In some cases, when a computer has a more current operating system installed, it will not allow an older operating system to write over it. That is why I said, reformat the hard drive. Remember, hardware drivers are written for Windows 10 now, so old drivers may not be functional any longer.
Jan 14, 2018 | IBM ThinkCentre M51 PC Desktop
Have a HP SR1010V, 33GB HD - XP Home. Want to 1) replace HD with a 100-200GB HD OR 2) ADD a 100-200GB HD and 3) ADD a DVD drive. What is best way to copy data to a new HD and to boot the new HD. Rather...
The easiest route would be to install the new hard drive in place of the old hard drive and place the old hard drive below the new hard drive and make it a secondary hard drive or slave drive. Once you have them installed this way you can install Windows XP Home to the new hard drive once you have it installed to the hard drive then you can copy everything from your old hard drive to the new one. Once you have everything copied from the old hard drive you can then format it within Windows to have 33GBs of space to store anything you wish. If you need more detailed instructions don't hesitate to reply.
May 19, 2010 | HP Compaq Presario SR1010V (568656) PC...
I am attempting to run a compaq EVO d510 with a recently imaged 160 GB hard drive. It flashes blue screen of death and reboots after loading agpcpq.sys. I think that the most advanced hard drive mode is...
If the image on your hard drive doesn't have all the right drivers for your system, it won't work, and you will get BSOD. can you boot into safe mode? If so, you may be able to uninstall a driver or two...it usually the last driver/file that successfully installed, not the one that doesn't finish loading, so see what the file "before" agpcpq.sys is. If you have a windows XP cd, you can try to get into the recovery console and then the command prompt, and typing "fixboot" ...or you can run the system file checker "sfc /scannow" ...but without more information, you may end up wiping it. Do you know what drivers are on the hardd rive?
Jan 12, 2010 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Samsung SpinPoint SP8004H 80 GB Hard Drive Logo
172 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
