Question about HP Vs17 17" LCD Flat Panel Monitor
Monitor is black, the blue lcd at the switch does not lite when switch is turned on. The internal fuse is ok. I tried to find a schmatic on I could check the power supply, no luck.
  • 2 more comments
  • Anonymous Jan 04, 2008
    hp vs19e
    same problem as you described
  • jen s Feb 22, 2008
    have the same problem as both of you, sometimes the blue light will flash twice after i have unplugged it for awhile...it is one year old.
  • Anonymous Feb 27, 2008
    I have the same problem
    I turn my computer on, it starts off with a "black veil" over it. I turn the desktop on and off, and I see the screen for like 4 seconds working fine, and then it just goes. I have no idea what makes this problem. But I know that my desktop isnt completely dead, theres something wrong with it.
    Also, I can't have a custom desktop screen in the background.
  • ray vaugn Apr 18, 2008
    same problem 13 months old.can't find a schematic
I have the same problem. Took it apart for troubleshooting. Found that if I disconnect the ribbon cable between the display driver circuit board and the LCD panel, I can turn on power and it will stay on. I can turn it on and off with the power switch. With the LCD panel cable connected, Power turns on (power light blinks) then apparently a fault with the LCD panel causes the power supply to shutdown. At this point the power switch does nothing. Now the big question is "Can you purchase a LCD panel?" If so, it probably costs more than a new monitor. Hope this was helpful.
Posted on Mar 08, 2008
Gateway monitor 2100 won't turn screen on, blue lite is on as if monitor is. but screen is not on. can it be fuse or what ? is not v-card
It sounds like the lamp for your monitor is no longer receiving power. While you can attempt to fix this issue yourself I wouldn't recommend doing so as it doesn't mean it will work after you attempt it.
If the monitor is under warranty still then you should contact the manufacturer about a RMA. If the monitor isn't under warranty then you should purchase a new monitor.
Nov 26, 2011 | Gateway Computers & Internet
Monitor won't go on blue power lite won't change to orange. don't know if its video card or monitor
This is easy to test - disconnect the monitor from the pc and start it alone. If it doesn't start and show the no source warning then it's the monitor, it has an internal fault. It will be cheaper to buy a new one than to try to fix it.
Jul 18, 2010 | ViewSonic VA1930WM LCD Monitor
When I connect my monitor to my lab top the green power light comes on then turns orange and I get "no signal" message on the monitor
you may need to tell the lap top to display from that screen the new screen has no image or signal so goes to sleep to save power.on your lap top try the (FN) key on your laptop then select a blue picture on the keyboad of to squears one black one blue this will alter the display.OR in windows look at Start>controal pannel>display
Jun 03, 2010 | Sharp LL-173C-B (Black) 17" LCD Monitor
The monitor shows a black screen but the green
Yes, there is internal main AC fuse, which should be OK because you can see the indicator light, you need to open it up and check for caps with bulging tops first, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 07, 2010 | Acer AL1714CB (Black) 17" LCD Monitor
The power button is violet, the monitor won't work
robyn_e_fox, Here is what I would try to do first if my 12 to 15 month old LCD monitor started doing STRANGE things!! If possible try to substitute a KNOWN GOOD monitor in it's place to make certain that your PC is working properly. If PC is OK then you know or are pretty sure that your LCD could be having an internal problem that a technician will need to diagnose and repair. Before paying for ANY repair you should contact the monitor manufacturer and complain about the short life and PREMATURE FAILURE of this LCD. Check to see if they also have a swap-out program in place. And last but not least check with the store where you originally purchased the LCD on what you should do. Hope this helped. loiue12fix on fixya lmistyrel @aol.com
Sep 29, 2009 | Computers & Internet
Monitor switches off!
An internal circuit may be failing.
Jul 03, 2017 | Neovo E-17DA (Black) 17" LCD Monitor
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Help
If the monitor was dropped, most likely you damaged the internal components that provide the picture, whether LCD or CRT. Try connecting it to another computer. If this doesn't work, check the monitor's display settings or operating system display settings for contrast or brightness. NEVER open up the monitor, because there is a high voltage capacitor that stores voltage even when the monitor is off and could kill you if it discharges.
Jun 11, 2007 | Envision EN-7220 17" Flat Panel LCD...
HP Vs17 17" LCD Flat Panel Monitor Logo
208 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
