Question about Uniden Cordless Phone
GE Cordless phone Model No # 27996GE3-A
I have GE Cordless phone Model No # 27996GE3-A with two receiver sets. When I dial, I can hear the person on the other end, however the other person can not hear me. Is there a "un mute" button or setting that will turn this phone into a normal phone?
Thx for the help
GK
  • Uniden Master
  • 1,551 Answers
I looked at the manual, and there doesn't seem to be a way to un-mute the mic. On other models, the Menu button is also the Mute button.. The only thing I saw that might be the cause is the following:
If this only happens on one of the handsets, did you register that handset? It must sit in the base cradle for 20 seconds before it's registered:
NOTE: In case of a power failure lasting more than 5 minutes, you must put both handsets on the main base cradle for 20 seconds to re-register.
Posted on Mar 15, 2016
  • 201 Answers
SOURCE: can't dial out
Can you hear the tones when you dial? Is there a (tone / pulse dial) switch or programming option?
Posted on Jul 07, 2007
  • 7 Answers
SOURCE: Cordless phone
press menu then globel setup and then press dial mode then change the the dial tone you want
Posted on Nov 10, 2007
SOURCE: No dial tone
no dial tone. the handset shows "searching".
Posted on Nov 11, 2008
SOURCE: Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Posted on Jan 08, 2009
SOURCE: How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Posted on Feb 05, 2009
My phone rings but i can't hear anything on the end
i have a GE 6.0 cordless telephone, i know tha it's ringing the number comes up on my television but I can't hear it ring?
Sep 23, 2009 | Uniden DECT 6.0 Cordless Telephone...
Jan 07, 2009 | Uniden Cordless Phone
No dial tone
Nov 08, 2008 | Uniden Cordless Phone
Dialtone
http://www.retrevo.com/samples/GE-manuals.html
follow the link above and also try to get an earlier or newer moddel manual ;) take care
Oct 22, 2008 | Uniden Cordless Phone
My answering machine
I think I found a solution. On my phone model 27996GE3-A, I unplugged the phone for a few seconds, plugged it back in and waited until the display showed the number of messages and then I pressed the "skip" and "review" buttons at the same time and then it announced the the language changed to english. Hope this helps.
May 11, 2008 | Uniden Cordless Phone
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
Ge cordless phone 27996ge3-a
Press and hold the "skip" button for at least 2 seconds and the phone will announce "English". Then all menu items will be in english.
Dec 31, 2007 | GE 21028GE3 Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Cannot hear person calling
I am having the same problem with the same model phone! The line works with another phone but not with the GE cordless. If I call someone with the GE cordless they can hear it ring and hear me talking but I cannot hear them speaking. Silver Spring MD
Sep 06, 2007 | GE 21028GE3 Cordless Phone
Uniden Cordless Phone Logo
353 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
