Question about KitchenAid KESC300 Electric Kitchen Range
Burners Blew I was cooking a big dinner, with the oven going and three of the four burners. Heard a pop and saw some smoke, and went to see if something burnt over. Then, a minute later, another pop, and saw smoke coming from under the burner control panel in the front of the stove. Both of the left hand burners had blown out, and won't work. Almost like a fuse blew? The right hand burners and oven are working fine, tho... Any ideas?
  • Anonymous Mar 18, 2014
    I WAS USING MYH OVEN I HEARD A POP AND MY WHOLE STOVE WENT OFF AND WILL NOT COME BACK ON
    I WAS COOKING DINNER I HEARD A POP GTHEN MY STOVE WENT OFF AND IT WILL NOT COME BACK ON
I had a similar problem while mine was still under warranty. Seemed like every time I used the oven and stove top for a major dinner it would short out and I would get an error code: F1:E6. They replaced the board under the display area, but it happened again about 6 months later. Turned out that when they made the oven they didn't insert a chimney like vent system from the bottom left side of the oven to the vent holes that come out the upper left side of the stovetop. This caused the panel to overheat and stop the entire oven from working. They replaced the board again and installed the "chimney vent system" and I haven't had the problem occur again (it's been 3 years!).
Posted on Feb 17, 2008
    President:
  • 1,314 Answers
If you will send me your model number off your serial plate on your range will be on front open oven door or lower drawer some where and when you bought it i need to check the service bulletins before i reply but dont rate me till were done
Posted on Jan 02, 2008
Electric Oven will not heat or come on
Sounds like you have burned out the element?
Aug 12, 2015 | Ovens
I was cooking dinner. Was using Kenmore oven on Broil and heard a loud pop. Everything went dead. Is my oven dead? Can it be fixed and how much would it cost? Would it be better to buy a new oven?
they dont make em like they used to anymore.. be looking under the top for a burnt wire somewhere..if the burners still work its ok if they dont. check your fusebox.. see if a fuse blew..
Mar 15, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Gas burners have a popping sound when trying to heat food in pans
Make sure you clean them properly, Call a repair man if noise persists.
Nov 06, 2013 | Magic Chef 31000 Gas Kitchen Range
Stove control panel not working
You do not have a fuse or overload button on a Maytag cook-top. If you heard a pop, it was the touch pad on your control board blowing out.
Oct 22, 2009 | Kitchen Ranges
After a "pop" - the oven no longer works
You should have thrown the breaker before moving the oven. The element likely shorted and blew the breaker. make sure the breaker is off. replace the element and plug it back in and reset the breaker.
Eric
Sep 22, 2009 | Ovens
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore range control panel not working
sounds like the control board blew on you replace it.
Dec 16, 2008 | Kitchen Ranges
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Cook top "popping" noise
make sure the heater elements are properly nested into their respective electrical sockets. if they get loose, then the electrical contact can be intermittent and arc/spark a bit..
Sep 10, 2008 | Kenmore 30 in. 44022 / 44029 Electric...
No spark on all burners, oven doesn't work either
Give me the complete model # from the sticker on the oven and I will try to help.
Nov 07, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid KESC300 Electric Kitchen Range Logo
368 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
