Question about Uniden GMR638-2CK (22 Channels) 2-Way Radio
Not able to communicate
The two handsets were working fine for over a year but for the last 2 days, when i press the buzzer or speak into either set, there is no sound / voice received in the other. this applies to both sets.
  • 45 Answers
First of all check if the channel on both the radios are the same. If its a year, then also check the batteries on the sets and then the antenneas. If still no result, I suggest you get it done thru a service center.
Posted on Jan 06, 2008
I have numerous times in last 2 days how do I get an answer?. Here goes again . How do I reset time on sony dream machine serial no.4841857
1 Plug in the ICF-C218 in a well-ventilated area free of moisture.
  • 2 Press "Clock" if you are not in the U.K. and need to set the time manually. Hold it for two seconds.
  • 3 Press the + and - buttons until the year is set correctly.
  • 4 Press "Clock" once you've set the year, and repeat this process for the day, hour and minute.
  • 5 Slide the "Alarm Mode" toggle to either "Radio" or "Buzzer," depending on your personal preference.
  • 6 Slide the "Alarm Time Set" toggle to either the + or - side until you've reached the time you want your alarm to go off at. Hold it down to adjust in 10-minute increments
  • Read more: http://www.ehow.com/how_7396985_instructions-sony-icf_c218-clock-radio.html#ixzz2jjJEJSA3
    Nov 05, 2013 | Home
    I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
    Alarm settings can be made with clock/radio on or off.
    The Alarm Clock/Radio is equipped with two independent alarm
    systems each of which can activate the Human Wake System Buzzer
    or turn on a preselected radio station.
    Using Alarm with a Preselected Radio Station:
    Select desired station using + or - Tuning Button [18] or select one
    of the 1-7 presets.
    Set the desired volume level using Alarm Level Adjustment [9]
    Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
    Display will blink with selected alarm
    Press alarm set button [16]
    Display will blink showing selected alarm hour and alarm mode
    and beep
    Press alarm Mode button [20] to select alarm mode
    Use + or - button [18] to set alarm time hours.
    Press set button [16] to set minutes using + or - button to
    set minutes.
    Press alarm days selections 1-7 (Sunday-Saturday) to select
    alarm days.
    Display will show the days on which you wish to be awoken by the
    radio alarm.
    Pressing alarm button 1 or 2 will confirm settings and a beep and
    display indicates radio alarm is set.
    Note:
    If alarm days or alarm mode are not selected display will blink
    all the days for a few seconds indicating the alarm is not set
    and the alarm will not be activated.
    If you would like to be awoken to the station you are presently
    listening to press alarm button 1 or 2 for more then 2 seconds.
    This allows the station you are listening to be stored into
    memory. Then follow above procedures.
    Using Alarm with HWS Alarm Beep:
    Display will blink with selected alarm Press alarm set button [16]
    and beep
    set minutes
    alarm days.
    buzzer humane alarm
    display indicates buzzer humane alarm is set.
    Note:
    Cancelling Alarm Setting:
    Alarm functions can be cancelled:
    and beep
    Press alarm Mode button [20] one or two times (depending if you
    were in the alarm radio or alarm buzzer mode) till display blinks.
    Press alarm 1 or 2 button again to confirm alarm cancellation.
    The symbol will stay on the display for about 2 seconds
    and disappear.
    You may also select days you wish to be or not to be woken after
    pressing the Set button while display is blinking. Press 1-7
    (Sunday-Saturday) of button [19] to make a selection.
    This is the figure of your device and you can find which button where is:
    Thanks.
    gylacz
    Jun 10, 2011 | Sangean RCR-1 Clock Radio
    How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
    This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
    Setting Radio Alarm
    1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
    Setting Buzzer Alarm
    1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
    Activating the Alarms
    1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
    Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
    I have the phonemate 2970 answering machine/phone and satellite extension phone. When I turn the sat phone on I get a series of beeps and the HOLD light flashes for about 6 times then shuts down. I...
    1. Remove the AC adapter plug from the back of the base unit (not from the wall); leave tel cord connected.
    2. While holding down the "set code" button under the cassette lid, plug the ac adapter back into the base. The screen will then display some numbers (110) etc.
    3. Hold down the HANDSET keys 1 and 2 simultaneously and then press the speaker button on top within 20 seconds.
    4. Press any 3 digits on the handset i.e. 1-2-3.
    5. After hearing a BEEP from the handset and base, press 2 on the handset. The base should then say "twenty-five", and the handsets will beep, confirming the new security code is enabled. Press talk or speaker on handset to confirm communication.
    6. The time/day stamp and remote access code will be cleared.
    7. Best to do this with the answering mach turned off.
    8. Restart this procedure if anything goes wrong (may hear a series of error beeps).
    I saved my manual and in it I had a fax Casio sent me with these instructions (i had this prob a few times years ago). Good luck!
    Jan 18, 2011 | Casio PhoneMate PMP3875BK
    Can not rec a dial tone, phone states no link to base move closer
    If “No link to base. Move closer to base, try again.” is displayed
    even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
    • Make sure the base unit is not being used.
    • Have both handsets and base unit nearby during registration.
    • Follow steps 1–3 listed below. You have about 1 minute to complete them.
    • Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
    If you re-register the handset using the other handset’s extension number, the other handset will not function.
    • If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
    • You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
    1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
    • The CHARGE indicator flashes.
    2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
    handset which has lost the communication.
    3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
    • When registration is complete, a beep sounds from the handset and the display shows the number.
    • Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
    Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
    My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
    To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
    with the handset down, enter #20 the screen should say MMC DISABLED
    1) enter in 1 2 3 4 1 # (that enables programming2.gif)
    2) enter in #55 the screen should say YYMMDDWHHMM
    3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
    press # when finished.
    Nov 12, 2009 | Samsung Prostar 824 Keyset Telephone
    How do you set the timeand date on a toshiba dkt
    Please try this..
    1. From main console phone (lowest extension number i.e. x100) pick up handset and dial following codes:
    2. For Date: 651 YYMMDD Redial ----(YY=year, MM=month, DD=day)
    3. For Time: 652 HHMMSS Redial ----(HH=hours in 24hr clock, MM=minutes, SS=seconds)
    4. For Day of Week: 653 X Redial ----(X=day of week 1=sunday, 2=monday....etc.)
    If won't work, try this
    From Extension port 00 (usualy station 200)
    1. Lift Handset Dial #652
    2. Enter Correct Time HH MM SS
    3. Press Redial
    4. Replace Handset
    Regards,
    Jeep Brainy
    Aug 10, 2009 | Toshiba DKT-2020-SD telephone
    IN 120 base keeps flashing CL
    This is due to the base unit losing power and needs the clock resetting.
    The handsets retain their clocks under battery power so this is a little misleading.
    To reset the base unit clock:
    - press the OK key
    - press the 'down' arrow twice until "DATE/TIME" is displayed.
    - press the OK key again, this will display the year. Enter the correct year on the handset numeric keypad and then press OK. (Only the last two digits of the year need to be entered).
    - The date is then displayed in MM/YY format, enter the correct date on the handset numeric keypad and then press OK.
    - The time is then displayed, enter rhe correct time on the handset numeric keypad and press OK.
    - The handset then beeps and displays "SAVED".
    - Press the "C" button and replace the handset on the base unit.
    The base unit should now stop flashing "CL".
    Jul 09, 2008 | Lands Phones
    Answering Machine suddenly speaks spanish
    1, Ensure that the telephone is not in use.
    2. Press and hold the skip button on the base to select another language.
    Jan 16, 2008 | GE 25932 Cordless Phone
    Lost comunication
    I solved this problem with a RESET of the handset. Instructions from the Philips website: Please perform a reset of your device. You will not loose your recorded data (phonebook and personal settings are being kept). 1. Unplug the mains of the base station. 2. Remove one of the batteries of each handset. 3. Put the batteries back in and re-plug the mains of the base station.
    Mar 09, 2006 | Xact Communication XG2200 Cordless Phone
    Uniden GMR638-2CK (22 Channels) 2-Way Radio Logo
    125 people viewed this question
    Top Uniden Radio Communications Experts
    Jason
    John
    John
    Greg Cann
    Greg Cann
    Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
