Cars & Trucks Logo
Posted on Oct 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a step by step with pictures to replace a starter
Larry Chandler
Level 3:
President:
  • Mercury Master 1,149 Answers
  • Posted on Oct 28, 2009
Larry Chandler
Mercury Master
Level 3:
President:
Answers
1149
Questions
0
Helped
451431
Points
3903
Hi:
If you need detailed help with pictures or diagrams to change the starter on a Mercury Mountaineer, I suggest you go to : www.alldatadiy.com
You can get a one year subscription to a full technical repair and troubleshooting manual, and can print out pages, wire diagrams and more.
How to fix a starter on a 2006 Chrysler pacifica
Hello A. J. Arland,
Most folks find it more economically reasonable
to simply replace the starter...
(see below)
You can check VERY reasonable prices at ROCKAUTO.COM ..
It is important to note... Your STARTER MIGHT be fine...
Your SOLENOID could be causing the unit not to operate correctly...
There are multiple test procedure...
I am ASSUMING you have already performed... because your question is merely REPLACEMENT...
First... single and most important step...
DISCONNECT THE GROUND wire at the battery...!!
Remove wires from starter.
(always tag where the wires connect... perhaps even a picture).
Remove bolts from Starter...
(always track where the bolts come from)
Reverse above steps...
Happy motoring.
Carnac the Magnificent
4helpful
I need to replace starter motor in my 2000 Toyota Tundra 4.7 L V8. Do I need to remove the upper and lower plenum?
No you do not need to remove the plenums. The starter is removed and installed from underneath the truck of from within the wheel well if the wheel is removed. You should go buy a Haynes or Chilton repair manual for $20 they are indisposable to do it yourselfers and will give detailed step-by-step instructions with pictures.
I need step by step instructions for replacing the starter.
Best way to learn how to do these jobs is go to the public library and find a Chilton's manual for your year of car. They usually have a really go set of instructions with pictures on how todo jobs.
Startup problems, at first no clicking or nothing 3rd time engine turned over but there was a high pitch wining i think from the starter itself pls help, Chef KB
It sounds like the starter solenoid has gone bad, Best thing to do is just to replace the whole starter. The starter solenoid is mounted on the starter, but to go through all that trouble to remove the starter, might as well replace the whole thing. Auto Zone carries the starter for your car and can give you the step by step instructions to get the job done with common tools. Good luck and when removing the old starter, take pictures with your cell phone to reference the wires when re-installing the new starter.
I need to replaced my starter for my 1993 saturn sc1
try autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
Replacing the starter
try www.autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
2helpful
Replacing 1990 toyota forerunner starter relay
1998 Kia Sephia - replace the starter
To put it very simple, if you plan on keeping the vehicle for any real length of time, go to your local parts store and buy a manual. Haynes and Chilton make pretty good repair books. They have pictures, step by step instructions, safety tips, and generally, what tools are needed. A good book runs about $25.00. If you're gonna keep it, buy the book. There is no way anyone can answer you question in the proper details needed on this limited site.
Good Luck and check it out.
Need to replace starter im not mechanical incline. i know basic
Get a chilton manual online if you a DIYer and it will save you time and money..Basic step by step-Remove postive batt cable. locate starter, obtain new starter to see location of mounting bolts,remove starter mounting bolts,remove wires firrst if accessable if not starter will lower when mount bolts out ,then remove wires noting where they go. hookup wires and replace in reverse. note:some can be hard to get to-always handy to refer to a manual Good luck..oh replace positive cable when aal is tight and right...
1helpful
Help
Check out AutoZone.com. They have instructions for how to replace the starter. No pictures, unforunately, but fairly detailed step-by-step instructions.
Here's the direct link:
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152800c4f7e
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
