would need complete accurate model # and serial # to be more specific.. looks like one of the turbo type ovens they put in subways.. best of luck, ttfn
you need to narrow it down What oven model is this the same oven that is used in dunkin donuts or subway. Are you getting any error codes. it is most likely a fan issue because if the mags were bad it woud not heat or cook at all. Also check the fuses and if there is a reset switch by the power cord try and reset that.
If the fan does not come on anymore, then it must have shorted out and needs to be replaced asap. The motor is more the likely to be a sealed 120 volt, single phase 60hz motor. Have someone that is familar with motors and electrical, remove it and have it tested. You should be able to get a universal to fit if you can't find the exact one. Should also be less expensive then an oem.
We run coffee shop, we already have turbochef conventional oven. We only bake cookies, crossant and ...
(More)
We run coffee shop, we already have turbochef conventional oven. We only bake cookies, crossant and sandwhiches. We are planning to have pizza. Is anyway you make adjustment for Pizza
Vikas: This is Manoj Tripathi. I have the same problem as you. What was the final solution? Manoj at...
(More)
Vikas: This is Manoj Tripathi. I have the same problem as you. What was the final solution? Manoj at 415.939.8500
