Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
VHS Tape I have a VHS tape of home movies that when placed in the VCR and played the numbers on the screen do not work when playing, REW or FWD they just stay at 0:00    When I play the tape it appears that nothing was recorded on it, but I'm certain there is since I wrote dates on it. The tape counter works on all of my other tapes, so I know it isn't my VCR.  I have tried changing the shell and the tape appears to fwd and rewind but the tape counter numbers still do not move and there still appears to be nothing on the tape.   HELP!! email any suggestions to me at Thanks
    Problem Solver:
  • 5 Answers
Possibly the tape is wound too tight and is not actually playing when in play mode.
Also, tapes can be accidentally erased. If it is placed on a speaker or other magnetized surface it will erase itsself. The magnet draws something out of it.
I'm not sure exactly how it works but I know it happens.
Don't give up just yet. Check with your local video rental store... maybe they know a trick that will help you.
Good Luck :)
Posted on Jan 27, 2008
Stuck vhs in vcr
check the tip in my profile
May 31, 2010 | Philips CCC130AT 13 in. TV/VCR Combo
JVC HR-S9500 S-VHS VCR. all functions work except the eject on the vcr. there is no eject on the plays, ff, rew, stops etc. I can't get the tape out.
the eject button is a plastic piece that turns and pushes down on the board and is more then likely broken open the vcr take off the front face plate and check the button, it will propaply fall out. you can use super glue and glue the button back in place
Jan 05, 2010 | JVC HR-S9500 S-VHS VCR
VHS won't play correctly - no picture, muffled low voices
Several things.
Check the tape, by opening the cover, to see if the tape is damaged. Look for signs of crinkling at the edges. This is often caused by the roller being worn on one of the VCR.
If it's damaged there's not a lot you can do.
If there's no damage try taking it out of the cassette box and fitting it in a new 'good make' blank tape tape box, discard the new tape in it. Still no good?
Next step, is the tape a movie/tv made by a commercial company. Or a recording on a blank tape?
Did it ever play? (if a movie) if not suspect a pirate tape report seller to FACT.
If a blank tape, try recording on a blank section. If that doesn't work and your video will record on other blank tapes. The tape has something wrong with it.
Some video recorders will play tapes with bad problems IE bad tracking, that others refuse to play, but you will either have to find one owned by a friend or buy one with that claim.
Sep 08, 2009 | Televison & Video
No video output when played on vhs
try cleaning the cylender head of your vcr you can do that by opening the unit or buying vhs vcr casset cleaner....
ps : check if you have to switch between tv and vcr via remote , and when you insert the vhs tape you are able to rew and frw and press play normally...if these are ok usually its a little dirt onthe cylender head....hope this helps...
Jan 01, 2009 | Panasonic DMR-E75V DVD Player/VCR
Re: Model PV-4523S
You can try cleaning it with a VCR tape cleaner to see if the pinch roller have build up on there. It could be that the motor isnt feeding the tape up against the recording heads properly and may need an adjustment. If you can take the top cover off, you should be to see what the problem is by the way the tape is being inserted into the machine.
Jul 29, 2008 | Panasonic PV-V4021 S-VHS VCR
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Dec 04, 2007 | Sony SLV-D300P DVD Player/VCR
Rewind or fast forward
Though not familiar with this model, VCRs of all sorts have an idler mechanism which drives the supply and takeup spindles. Either the idler is somehow defective and slipping, and, assuming this idler is belt driven, the belt may be slipping just enough to cause a no Rew/FFW condition. If you had access to a test tape jig (a clear dummy tape, which allows a tech to view what is happening in the area normally obscured by the loaded tape), this might give a clue as to what is happening. On alot of machines, a problem with Rew/FFW would also mean a tape takeup problem in standard play, result in tape spilling out inside the machine. Sensors would catch this condition and go into a error mode, as yours is doing. One other thing which might be happening here, is the pinch roller not being disengaged from the capstan in the Rew/FFW modes. I think this is where I'd look first, and you can probably see if such is happening just by pulling the cover off the VCR. The pinch roller is just to the right of the rotating video head. In the play and forward/rev search modes it will press the tape up against the capstan (a rotating shaft). When in Rew/FFW, the pinch roller should be pulled back from the capstan, maybe 1/4 inch or so. Whatever the case, repair will likely take someone tech savvy. Costs might not be economically justified, with the low-cost, disposable rigs sold in the last 10+ years.
May 29, 2007 | Sanyo VWM-950 VHS VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
551 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
