Heating & Cooling Logo
Posted on Oct 28, 2009
What does Comfort Zone II Error Code E5 mean?
Jeff Bryan
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Oct 29, 2009
Jeff Bryan
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
5032
Points
39
If I'm not mistaken, it seems like it means there is a problem with the outdoor temperature sensor. This is strictly from memory though and I could be wrong. If you press the up and down arrow buttons at the same time it should display the outdoor temperature for a few seconds and then the indoor humidity. You might try this to see if it displays an outdoor temperature that is close to being right. If it doesn't there is a good chance the sensor is bad or there is a broken wire somewhere.
I hope this helps!
E1 error code on a cz220 comfort zone model heater what does it mean
The E1 error code on a Comfort Zone CZ220 heater indicates a problem with the high-temperature limit switch. This switch is a safety feature that shuts off the heater if it overheats.
To clear the error code, you can try resetting the heater by unplugging it from the power outlet and waiting for at least 30 seconds before plugging it back in. If the error code persists, it may indicate a more serious issue with the heater that requires professional repair.
Have a comfort zone inferred heater that the display comes on but won't heat up. When I try and turn up temperature I get a AO5 code. What does this mean?
Make sure the unit is clean. Especially, the blower wheel. If that doesn't resolve your error code then follow these instructions.
http://screencast.com/t/RoXS239ndAhF
Look that over please, you can clean the blower wheel at the red arrow, jumper the two switches at the blue arrows as *brief tests only* just to see if the unit runs and begins to heat with the jumpers in place.
If it runs, replace the item that failed open.
If it does not run, the control module, Item 5 marked with green is most likely bad and needs to be replaced.
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
What is the error code E5 on bluestar air conditioners mean
Problem
Overheat of inverter compressor motor
Cause
Shortage of refrigerant amount Leakage of four way valve
Defect of connector contact
Carrier Comfort Zone 2 Master is flashing E5
Check float switch. E5 is loss of 24 volt power on some models.Russ
I get the error code E2 It only shows 2 zones on my 4 zone syst
I reset the circuit breaker to the panel and everything is good now.
Top Carrier Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
