Question about Canon S 330 InkJet Printer
Canon iP90 Printer Ink Issue
All of a sudden - my black ink will not print on paper. I can get color to print - but not black. I've changed the cartridges and also done the deep clean. Nothing helps.
Any suggestions on what to do next?
I have had the same issue with my iP90.  I think this results from the black ink nozzle becoming clogged.  I was able to get mine to print by cleaning the nozzles.To clean the print nozzles open the Canon IJ Printer Utility, select the printer from the list of available printers and click the maintenance button.  Then, select a cleaning or deep cleaning cycle.
Posted on Jan 03, 2008
Ip90 printer does not print blac on a test after
Sounds like the printhead is plugged on the black side. A new printhead is #qy6-0052-000 around $40.00. That model also needs a firmware update to help it clean the printhead better.
Jun 23, 2009 | Canon PIXMA iP90 Mobile Printer
My IP90 stopped recognizing the instalation of the color ink tanh
Take to a ink refill store and ask the to test on there machine(cartridge world etc) it will tell if cartridge is good or not! hope this helps!!!
Jun 21, 2009 | Canon PIXMA iP90 Mobile Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
Apr 27, 2009 | Canon PIXMA iP90 InkJet Printer
Printer will not print black ink.
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head..slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out.
5. Have severasl paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. May color and black and white print is back!
Hope this helps.
cw
Feb 16, 2009 | Canon PIXMA iP90v InkJet Printer
IP90 stopped printing black
if ink is ok than have to change print head for black cartridge
Dec 16, 2008 | Canon PIXMA iP90 InkJet Printer
Canon iP90 will not print black text - it will print any other color text. When I print a test page - it only prints the small flag top left page. I have done a deep cleaning - three times. I have replaced...
hi karen,
If you are sure that the ink is present, there two other possibilities: Purge unit work properly so the ink cannot flow down from ink tank or Logic board of you printer is faulty.
Dec 13, 2008 | Canon PIXMA iP90 InkJet Printer
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
My ip90 Canon printer only prints in purple
Try selecting an option in the printing properties to print in grayscale or black and white (you usually only have either one or the other). This will utilise ONLY the black cartridge, the color will remain dormant which should make your prints come out in black and white - if not, your black cartridge, or the space between the bottom of the black cartridge and the paper is contaminated with color ink. Good luck!
Sep 07, 2007 | Canon PIXMA iP90 Mobile Printer
Canon S 330 InkJet Printer Logo
230 people viewed this question
old marine
old marine
