Question about HP Pavilion F1703 17" LCD Monitor
Power Problem I had an f1703 that started having the infamous blacking out problem about a week after the warranty expired. I argued with HP until they finally sent me a replacement which was identical but refurbished. That was about 2 years ago (I think), and I haven't had any problems since. Then this morning when I turned on my computer, the blue power light (around the power button) came on for just a few seconds, the screen stayed black, a of hissing noise came from the speakers and the power light went off. I turned my computer off and back on several times and the same thing happened every time. I have also tried unplugging the cord at the power supply and plugging it back in several times, as well as unplugging the cord from the back of the monitor, and I always get the same result as I do when turning on the computer. First of all, is it possible that the problem could be with the power supply cord rather than the monitor? I'm just wondering if I should try replacing that before I invest in a new monitor. Second, if I do end up replacing the monitor, can I get ANY monitor that is fairly comparable to the one I have, or do I have to match certain specifications? Can anyone recommend one that is good but fairly priced? Thanks in advance.
  • 38 Answers
The hissing noise on your speakers is because of arcing. Do not try to operate repeatedly or you may do severe damage. The most likely culprit is the inverter board but you will have to disassemble the monitor to find out. Any loose connection that results in an arc will create noise on speakers. Hissing is usually a result of the high frequency/ voltage output small enough amperage to not blow your power supply If it were a DC arc you would just get a one time pop.
Posted on Jan 15, 2008
Hello, I have had my monitor now about 3 years. I have been using it for about 2 years. Last week it started blacking out and would come back on with resetting the monitor power switch. yesterday the...
it sounds like the power supply
if you open the monitor follow the power cord and you should see the on/off switch then it will lead to a transformer and the power supply circuit maybe its a loose connection you need to find a technician who fix electronics
Aug 17, 2010 | ViewSonic Computers & Internet
Tv black out on me and it stop working. No red power light.
My friend bought a Poloroid tv, similiar to yours. The power supply went bad 2 weeks after warranty expired; he had to pay to have a whole new power supply installed - roughly $250. Two weeks later my Toshiba (same age) won't turn on - no lights or anything. Same thing - power supply. Sounds like yours is in the same category. Hopefully you bought the extended warranty.
Aug 03, 2010 | Protron PLTV-32 Television
Hp f1703 lcd monitor has no power at start up, bla...
guest, First thing to do will be to visit this web blog:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading to see if anything seems familiar to your problem of BLACK screen. If it helps you out a little then come back here and rate this response and tell us what action you will take to fix your unit. 12fixlouie
May 19, 2010 | HP Pavilion F1703 17" LCD Monitor
My screen saver doesn't work I WAS TOLD TO REBOOT AFTER CALLING FOR OVER 11 MONTHS WITH RECOVERY DISC AND IF IT DOESN'T WORK THEN I WAS ADVISED TO CALL BACK AND GET AN ORDER NUMBER SO THAT I CAN SEND IT...
Today is the 9th. Your warranty has expired.
Before today, did you get an RMA (Return Materials Authorization) number, which entitles you to send it back, under warranty, to get it inspected/repaired?
If you have an HP "incident-number" that was created before today,
you might still be able to request an RMA number, arguing that the
incident was opened *before* the warranty expired.
Nov 09, 2009 | Acer Computers & Internet
Officejet Pro L7590 printhead message (printheads only 2m. old)!
Pull out the printhead from the computer and check the date under "warranty ends" If the warranty period did not lapse, call HP technical support and tell them about the problem. They will replace the printhead for free. I have gone through 3 black/yellow printheads and I received the replacement printheads via FedEx within 1-2 days. They will send you a pre-paid envelope to return via U.S. Postal Service via US Postal Service.
If the Warranty date on the printhead expired, then you may have to come out of pocket to replace the printhead since HP will argue that they are not obligated to replace the printhead since the manufacturer warranty lapsed.
If this is the case, check to see when you purchased the printer. If the purchase was within a year, the retailer (i.e. Best Buy) is on the hook since there is a 1 year implied warranty on products such as printers, regardless of whether the expiration date on the HP printhead expired.
Hope this helps
Aug 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Monitor going black
My HP f1703 is almost 3 years old and started having this same problem. My fix got the display to stay on. Don't know how long this fix will work. I set the monitor brightness to 51 and contrast to 41. You may have to adjust to your levels to your appropriate enviroment. Levels may determine how long the monitor stay operational. Do NOT set your monitor brightness to factory levels it will just start to recreate the problem again. Solution: The monitor should be on with the blue button lighted. If the screen is acting up (you turn it on and the display lights up and then it turns off within 2 to 5 seconds) Try decreasing the brightness level down as much as possible. Wait 15 to 30 seconds and see if the display comes back to life. If not, turn the monitor off and on again and try the procedure again, if necessary. Cause: I believe the monitor brightness level, set at 100 by the factory setting, is over driving the display and causing the protection circuit to cut off the flouresent lamps that light the display. HP had an issue with this display, and had a notice to replace them if the problem occurred during the warranty period. They extended the warranty period from Jun 04 to Feb 06. Check with HP Technical Support to determine if your monitor is cover.
Oct 10, 2006 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
401 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
