Big screen tv, got wet
6 year old thought was helping and sprayed glass cleaner on big screen tv. Now there's a black area on bottom of tv. How do we get rid of black shadowy area.
  • 3 more comments
  • Anonymous Jan 02, 2008
    my tv is sony LCD we got fire but not on tv only lot of smok and water tv not working please give me someting
  • Anonymous Oct 01, 2008
    my son decidid to spit juice at my sisters tv .44 inch rear projection sony ,now it ran down the front and has seaped inside the screen ..leaving a dark shadow about 6 inches across and 3 inces up ...please help ...have been told to let it dry but dont hold much hope :(
  • Anonymous Dec 24, 2008
    Woke up to the TV being soaked from the inside.  Supposably NO ONE did it. Dont know if I am suppose to use the hair drier at a distance or what.  Need help.
    I have had my husband use windex on it and soaked up into the screen, a very large spot 12" x 12" at least in total.  It actually dried up on its own.  BUT windex has chemicals that dry faster.  Water doesn't.   WHAT TO DO?????
  • Anonymous Apr 16, 2009
    my son spit water onto the screen of our rear projection, now there's a stain behind the screen.
  • changa112 May 12, 2009
    My dear 3 year old daughter put water all over our big screen projector tv and now there's a big water spot. It almost looks like it's spreading from the bottom. My husband hasn't noticed or else he'd have a fit! How do I fix this or is it the end of our tv?
My celing was leaking like it was raining out side, but my son ran some bath water and for got he turn the water on and left it ran all over the floor, and i'm down stairs watching the water come down full speed on my big scren tv,i tried drying the tv with a floor heater from front to back wake up the next morning tv still dosen't come on.. what can be the problems,............... please you can reach me at Queenlicious100@gmail.com. i really ned to no i love my tv
Posted on Oct 21, 2010
Son sprayed cleaner on tv.
I have not a clue what to tell you, but doubt the cleaner is the cause of this. In any case the TV is so old you will not be able to get parts.
Jul 09, 2017 | Televison & Video
My 03 focus wont shift to overdrive
are there any codes sounds like your overdrive shift solenoid is stuck open or closed
Nov 16, 2012 | 2003 Ford Focus
Black line on scans with neat receipts mobile scanner
Multiple lines appeared in every scan right after scanning a document from a credit card company that had those nasty adhesive strips used to attach credit cards.
First, I scanned multiple full pages to see if the problem would clear itself. After about 6 pages, I was able to identify the specific areas where the lines occurred on a document.
Next, I sprayed a tiny bit of glass cleaner (I used Sparkle glass cleaner, but I suspect any brand would work) onto an 8.5x11 sheet of plain paper in the area where the black lines appeared. NOTE: DO NOT SOAK THE PAPER, just get it damp.
Finally, I ran the dampened paper through the scanner. After each run, I would compare the result to the prior scan. As each streak was removed, I used a different piece of paper wetting only to address the remaining streaks.
After only a few runs, the streaks were gone (in my case).
Hope this helps!
May 14, 2012 | NEAT Receipts Mobile Scanner
How do I clean the TV screen?
Pleadge has a new product out that is just for cleaning electronics like tv and computer screens. it works great
May 08, 2011 | Samsung Televison & Video
Can we seperate the tv from the speaker to transposrt it up stairs?
You should be able to take the screen off and the top black plastic shroud that holds the mirror off to transport it.
1) To do this, you will pull the speaker grill cover off on the front bottom.
2) I think there are four screws at the bottom of the screen holding the bottom in place. Use a 1/4" socket.
3) Disconnect the wire harness going to the screen by squeezing the tab on the connector - very easy to do.
4) Remove all the screws on the black plastic shroud - about 8 of them. Have someone hold your screen and gently lift the screen off. The black shroud I think still has some screws holding it in place that become visible once you lift the screen off.
5) Once the screen is off, there should be a set of screws that are holding the shroud down. Remove those and gently put the shroud on the floor where the mirror cannot get damaged.
6) Installation is reverse of the above.
Note: This would be a good time to clean the mirror and tops of the CRT bulbs. It will make your picture much nicer if it hasn't been done. Use a non streaking glass cleaner on the mirror and bulbs. For the screen, just wipe it down, don't spray it with glass cleaner.
Feb 26, 2011 | Toshiba 42H83 42" Rear Projection...
My 6 year old Kenmore Elite DW has started leaking and has a musty smell. The dishes are clean but food residue is left on the inside door and black gunk builds up on the bottom of the dishwasher.
Use a wet/dry shop vac to clean out the strainer and drain from the inside of your machine. A musty smell is a sure sign that food particles have clogged your drain BUT can also mean that your wash/spray heads have become clogged as well. Use a pipe cleaner on the spray heads and run water over the jets to make particles flow to the big hole in the center of your wash heads, then reassemble. Don't forget to put those little plastic looking rings back exactly the way you found them or your wash heads wont turn properly. They are usually made of teflon to lubricate the spray heads.
Mar 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Black haze covering picture after "pop" noise
That's a very old model to be only 1 year old?
It needs a Z-Sustain PCB anyway.
Thanks.
Sep 08, 2009 | LG DU-50PZ60 50 in. Plasma Television
Black opaque line or bar
if its is viewable when off then yes its water or oil.between the screens.these screen don't normally come off from the front.
they have to be access from the rear.
could be big job.
only way to tell is to remove the rear cover.
Apr 13, 2008 | Hitachi 51F500 51" Rear Projection...
Dull picture
Yes you can take the back bottom of the tv off.You will see 3 bulbs 5or6" in diameter.take a very soft clean cloth spray cloth not bulbs.windex persoal cleaner for your glasses ect.wipe bulbs gently removing dust.Above thes lights are the mirror maybe 10"by12" clean that to spray cloth not mirror than wipe clean"Now get limber and try to reach the inside of the big screen and wipe completely.
Dec 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
856 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
