Printers
Problem for Printers
Generic problem for all Printers
Canon iP90 Printer Problem
By Sld323 on Jan 02, 2008
My canon iP90 is not printing the black ink. I have tried everything and don't know what else to do.
I've changed cartridges about 6 times, I've cleaned, I've deep cleaned, I do the test prints and sure enough - everytime it's only the color ink, no black
I don't know what else to do?
thanks
Comments:
Jan 04, 2008
- Thanks. This may be the problem. I'll find a Canon place here to look at it. Thanks
Same Problem
Feb 13, 2008
-   I have the exact same problem the color cartridge seems to work perfectly. However, no black in at all. I've cleaned, deep cleaned multiple times. I've change ink cartridges included purchasing brand new cartridges to make sure they were fresh. Nothing works.-   Guest
Jan 15, 2008
-   Same problem here on an ip90. Replaced black cartridge, cleaned a number of times and deep cleaned. Colour works but no black...-   Guest
Best Solution
posted on Feb 12, 2008
Very Helpful)
Jvever
Rank: Apprentice
Rating: 100%, 1 votes
I have 2 MP 390s. On one the print head is stuck on right and does not move. On the second the black ink does not print but everything else seems to be fine. How can I remove the print head from the stuck machine and place it on the other one?
Jake, Florida
Was this helpful?
Yes
No
Solution #2
posted on Jan 04, 2008
Helpful)
mater478
Rank: Guru
Rating: 87%, 83 votes
hi i am a certified canon repair teck for this product. the next thing to try is replacing the printhead which can be purched directy from canon at 1-800-ok-canon or at a canon repair center which canbe located by looking on there web site or by calling them. the only other thing i have seem cause this problem besides the printhead is the main logic board. out of two hundred repaired i have only seen that once be the main logic board. also when replacing the printhead use brand new inks with the new printhead and run one deep cleaning then test print. hope this is helpfull.
Was this helpful?
Yes
No
Solution #3
posted on Apr 15, 2009
Very Helpful)
mail159
Rank: Guide
Rating: 85%, 5 votes
take printhead out and put cleaner or turps on gauzes, dab off with paper towel, reassemble and run clean programme - this worked for me and from no black output I ended up with full function printer
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Oct 03, 2009
Not Rated)
bibi_nedelle
Rank: Apprentice
Rating: 0%, 0 votes
I did what "mail159" did and it worked instantly. ("take printhead out and put cleaner or turps on gauzes, dab off with paper towel, reassemble and run clean programme - this worked for me and from no black output I ended up with full function printer ")
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
MP 620 printer is it a good buy
Answer
konika minolta 1600 magicolor
Answer
replace photodeveloper black still asking me to replace have done three times still saying replac... (More)
Answer
the paper keeps being pushed out after going through the loading sequence
Answer
Hi I have a Brother HL-6050D/N that comes up with Error code E60. What is error code E60?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Printers:
Top Printer Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
