Question about JVC PD-42WX84 42 in. HD-Ready Plasma Television
42" Plasma Displays only Green Screen
For the past three days, my plasma only displays a green screen, not the picture! I checked the cables -- everything is fine. The TV is mounted to the wall.
I can't find the instruction booklet, but I purchased the TV in around June/July 2003.
  • 1 more comment
  • Chief2002 Feb 25, 2008
    Has anybody encountered a problem with their Plasma TV displaying too much green? (Looks like watching the Incredible Hulk.)
    I noticed that when I am watching cable (HDTV DVR) the picture is green. However, when I am playing a DVD its really good. I am using Audioquest Component Video Cables to play DVD (Denon Receiver and Denon DVD player).
    Could it be my cable connection or converter box?
  • vietmeierk Jun 29, 2008
    I have had a plasma for 6 months, when I bought the tv I purchased an hdmi cable with some kind of filter that attaches between two hdmi cables and adjusts the picture. Yesterday my dad turns on the tv and gets a green screen so I turn it off and on and off and on sometime fixes problems with the screen. Turned the cable box off, tv on and all that stuff. messed with the tv settings. I came to the conclusion that the hdmi cable was causing the problem so I used a coax and hooked it up and it worked but the picture is really crappy. went to walmart got a new hdmi cable hooked up and i have the green screen again???
  • Jeffrey Johnston
    Jeffrey Johnston May 11, 2010
    Green screen problems are usually video cable problems. dds426 you should try a different cable, even if you have to run it externally, to check the cable.
    Chief2002's issue sound more like a calibration issue. Chief, how is your HDTV DVR connected to your TV? Does your DVR have it's own color, contrast, etc., settings?
Dds426's reply:
The problem was not a cable connection. A chip needed to be replaced at the tune of over $600j (includes $200 for the repairmen coming to my home to dismantle and take to the shop and return it).
Posted on Apr 07, 2008
Color is Messed up on my JVC PD-42V485 There is More green then any other Color Help!!!!!
There are many reasons for this fault, that occurs with a plasma display. Without seeing its present screen, nothing can be adviced. If you wish to get more details about these faults to Plasma Displays, check this link. . It has screen shots to many faults that can occur to a plasma display, and measures to taken to rectify it. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 26, 2013 | JVC PD-42V485 42 in. EDTV-Ready Plasma...
Flashing Green Screen and lag
A green screen display to plasma displays is a bad symptom. It might be a panel defect. You just get into the site named 'Electro-help' by search, and get the site begins with 'electronicshelponline.blogspot' as its URL. There is screen shots to different faulty screens to plasma displays, which I can't include all of them this by this window. Check them and make confirm.
May 24, 2013 | Televison & Video
Green line screen
The green line wit plasma displays denote a fault to its panel. But before confirming it, a proper check should be done. Check the site lined below. There are screen shots to defective plasma displays. Pull up older posts there. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.
May 05, 2013 | Panasonic TCP50S1 50 in. Plasma HDTV
Troubleshooting plasma tv
Normally green display to Plasma TV indicates a panel problem. But before confirming it, a through check is necessary. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. Faults to plasma displays are given in detail with screen shots. Check it.
Apr 23, 2013 | Pioneer PureVision PDP-4340HD 43 in....
My 42 inch sylvania hdtv screen is broken and not showing a picture
If the display panel (PLASMA DISPLAY PANEL--PDP) is damaged or broken etc it is fatal as the cost of the part alone will exceed the cost of a new set.
Oct 15, 2012 | Sylvania 6842THG 42 in. Plasma HDTV
Fujitsu P42HHA30ES Plasma TV screen has stopped displaying
It sounds as though you have a fault on the Power supply, the fan doesn't not normally fail on this model. If you'd like your screen repaired, please call 0208 731 3432
Jul 11, 2010 | Fujitsu P42HHA30ES (Bundle) 42 in....
Hello. there is some green lines appearing on my 42 inch norcent plasma monitor display. what could it be? usually it starts after one hour of the tv being on. and if I leave it on for more thatn an hours...
Dear Sir,
Welcome to Fixya.
The problem is related to plasma it is very difficult to fix the problem,so solution is you have to replace your tv plasma screen.But it is too much expensive.Depending on your Plasma EDTV model and size estimation can be done.If it is in warranty you can get free replacement.Visit nearest Norcent Service Centre for more detail.If you have any problem regarding this issue leave a comment we were happy to assist you.
Have a Nice Day.
Oct 08, 2009 | Norcent Technologies PM-4203 42 in....
Vizio P2 42 in. HDTV-Ready Plasma
Search Google "Screen Burn-In."
Mainly Plasma screens are affected by it.
Sep 20, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Maxent 42' Plasma sound but picture looks like red, green and whites digital specks
the color card in the plasma is not okay.ihad the same problem and fixed it.
Apr 25, 2007 | Maxent MX-42HPM20 42 in. Plasma HDTV
JVC PD-42WX84 42 in. HD-Ready Plasma Television Logo
158 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
