Question about One For All URC4220 Remote Control
Insignia t.v. i tried the code for insignia and hottong the set button to search for the code and still can not find it. what else can i do
    Genius:
  • 1,694 Answers
Try www. remotecodelist.com .....T.
Posted on Jan 02, 2008
What are the codes for insignia tv
1937,1925,2184,2193. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Dec 13, 2015 | Insignia Televison & Video
I have a phillips rc44331/01 and i need code for my insignia ns-lcd37
0281,0260,0235. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
Dec 20, 2014 | Insignia Televison & Video
How can I reset my insignia tv #NS-LCD32 to global volume unlock with a RCA universal remote
Try this solution by another user:
timyorba 1 solutions Jul 21, 2011
So, For anybody who doesn't know yet, you do not need the factory remote to restore button functions to your Insignia IS-LCDTV26. All you need to do is program a universal remote that can power on and off the TV, then
"**press the "MUTE" Button 10 times successively**"
and Voila! Unlocked, you should see the status appear in the corner of the TV if everything worked, if not try another tv code or try the manual search function on the remote to find another compatible code set.
Dec 26, 2012 | Insignia NS-LCD32 LCD TV
Locked how to unlock
Dec 26, 2012 | Insignia Televison & Video
I need the code list to program my big button remote. My brand of TV is Insignia
Big Button remote control have pre-programmed with 3 digit codes. There are no code for Insignia tV with it. Codes for this TV are:
0103 0189 0217 0135 0133 0116 0167 0456 0029
Anyway try a code search method. Some times, ti might help you.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jul 16, 2012 | Big Button TV Universal Remote
WHATS DE CODE NO.
Hello
You are in need for universal remote code for Insignia TV, I assumes and post this solution.
Four digit universal remote codes for Insignia TV are:
0103 0189 0217 0135
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
CODE SEARCH METHOD
OK.
Sep 11, 2011 | Insignia 42" LCD Flat-Panel HDTV
I need code for insignia dvd-vcr combo to go with my rca rcu300 remote control
In the manual there is not insignia dvd or vcr code but you can search for it using the remote.
If your TV, VCR, DVD, or Cable Box does not respond after you have tried all the codes for your brand, or if your brand is not listed, try searching for your code by following the steps below
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE SEARCH.
3. Press and release the device button for the device you are programming (TV, VCR/DVD or DBS/CABLE). The INDICATOR LIGHT will blink once then remain lit.
4. Press and release OFF/ON until your device turns off. Important: You may have to press OFF/ON up to 200 times. 5. When your device turns off, press the ENTER button, the INDICATOR LIGHT will go off.
http://support.radioshack.com/support_video/doc67/67859.pdf
May 05, 2011 | RCA RCU300 Remote Control
Where to get remote codes for Comcast?
there are a couple of ways to go about it... you can either do a code search with the remote by pressing the tv button then hold down the setup button until the tv button blinks twice. Then press 991 the tv light will blink again then press 1 and then power. then you would press the channel up button until the tv turns off. Then press set up and that will lock in the code. If you pass the code and the tv will not power back on through the remote repeat the same process but press the oppisite channel direction. The other option is search google for your tv code.
Jun 23, 2009 | Insignia 720p Widescreen LCD HDTV
Emerson Jumbo universal remote not working with Insignia LCD tv
The code is under Sansui. It's code 135. Don't ask why. But it works and fully functional.
Jan 03, 2009 | Insignia LCDTV26 26 in. Television
Remote control code needed for this TV
Need to program my Insignia TV to my Direct TV remote. Need code
Nov 07, 2007 | Insignia IS 20" TV040919 TV
One For All URC4220 Remote Control Logo
29 people viewed this question
Top One For All Televison & Video Experts
S. Gontko
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
