Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Message on tv screen
I have a Sony Trinitron SRS 36" flat screen tv that is only 2 years old. About a month ago, a black box appeared on the bottom half of the screen and random letters flash in the box over and over. The box would eventually go away, but lately it does not unless the tv is unplugged for awhile. The tv is in a cabinet but the entire back of the cabinet is open, so it is not getting too hot. Is this something that is going to be an easy fix or is this a bad problem?
    Novelist:
  • 192 Answers
The text mode in the closed caption is turned on.Turn off the closed caption.
I don't have the schematic in front of me, so, I will wing it.
There may be a button on the remote that says CC, if so then use that button to turn it off, if not then go to the customer menu and you may have to search a bit.
Either way it's an easy fix and you can do it yourself.
If you can't find it, then, reply and I will give better instructions when I get into my shop next week.
Posted on Jan 02, 2008
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Blackout area on screen
Make sure the TEXT and CAPTION options are turned off.
I am not sure about the Sonny's, but on my Toshiba a black box appears when I inadvertently leave one of the close captioning (CC) on for text or captions on (such as CC1, CC2, etc.).
Feb 15, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do i fix this
I just posted this in a previous message:
"In both cases, I think you are either suffering from a failed power supply or the supply is cycling because of a 'downstream' problem that could be in the high voltage circuit. In each case, the blink count probably would tell you approximately where the problem is located but only a Sony tech will have access to the codes. After all, we are only mortals.  "
Aug 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony FD Trinitron WEGA Won't Turn On
The key here is the count of the blinks. I'm assuming that the model number is KV-36FS120. Please post the blink count. It should be a count-pause-count...
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony WEGA Trinitron SRS BBE 32'
How do you get the green display off of the tv screen?
May 04, 2008 | Sony FD Trinitron WEGA KV-29LS35 29" TV
1999 36" Flat screen Sony Trinitron TV
Hi there!
There may be dry joints in the Line Stage where the Line Transformer is situated. The move may have loosened some components off the board. If not familiar with TV Electronics please refer to a repair technician. Regards and good luck, JUS004
Mar 31, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony WEGA KV-36FV15: Picture problems
I THINK YOU HAVE A PROBLEM WITH DEFLECTION - I SUGGEST TO REPAIR IT BY TECHNICIANS - THAT TV IS UNDER
WARRANTY - DELFO
Mar 20, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
36" Sony Trinitron blinking red 4 times-PLEASE HELP QUICK!
Sounds like a typical high-voltage failure. Could easily cost another $300 to have it fixed. If it is less than about 6 years old I'd say it was worth fixing. If you want to DIY, then pull all the electronics out (label all the connections) and send it all to either Module Exchange at 972-298-1212 or PTS Electronics 800-844-7871
Feb 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
114 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
