Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
Problem for Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
The signal do not going thouth to the router
By edwardramos on Oct 28, 2009
the signal do not going thouth to the router to the computer
Solution #1
posted on Oct 28, 2009
Not Rated)
avmann
Rank: Guru
Rating: 92%, 27 votes
Are you saying you are not getting an IP address? If you are, then there is two way communication happening between your router and the computer. Is the router getting an IP address off the WAN? You need to verify this by logging into the router and looking for the WAN setup or status. If both of those are true then you have a config issue either on your firewall or the routers routing table or firewall. Check your computer first to make sure it's allowing traffic from the routers LAN IP address. Then check your router's routing table and the firewall settings.
Was this helpful?
Yes
No
Popular Solutions for Encore 802.11G WIRELESS LAN
Questions and Unsolved Problems for Encore 802.11G WIRELESS LAN
Do you recommend Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH?
Answer
Answer
I need help to get my Encore ENHWI-G2 ROUTER working. I am installing with Windows XP on a Toshiba... (More)
Answer
I have an ENHWI-G2 encore wireless router. i tried to install it in windows vista but always... (More)
Answer
I have an ENHWI-G2 encore wireless router, 3 of its slots are used, 1 for cable modem, 2 for 2... (More)
Answer
i cant connect with my router encore how is the right procedure
Answer
I'm using an encore 802.11g wireless router after about 20 minutes on my brand new dell inspiron... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Encore 802.11G WIRELESS LAN...:
Top Router Experts
Rank: Guru Guru
Solutions: 3634
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
