hi i have a juki 8700-7 whit computer CS-910-a and it showing
error 007 as sun i turn the machine on tarth bepeng like bip bip bip
can you please help me
hello there first please tell me the model of control box? is that error appear emmdiatlty when turn power ON? please email me at ( [email protected] ) i will try to do the best to resolve this problem. best regards ashraf abozid
lets start by going over the beeps and lights. when you power the unit on. it should go Blue and stay blue. this means the unit is so far functioning correctly.
if your unit turns on lights up blue, then yellow , then red and stays red you have an issue
if you are experiencing the first scenario, press the power button till it goes red. which is standby mode. then press button again till you hear two beeps, let go. make sure you have all your cables plugged in. this will send you to the diagnostic screen on the ps3 to select anyone of your options. since you are not getting a video display select the display settings and reset yours according to your type tv. if you are using a standard old school tellie, then its 480i, if you are on a plasma or lcd it would be 720p,1080i or 1080p. then you should be good from there
okay, if you are experiencing the second scenario its a much more severe issue. the GPU on the motherboard has gone bad, which is common on ps3s. if it is under warranty contact sony and they will send you out a refurb'd unit. if it is not under warranty there are a few good companies out on ebay that reflow or reball gpu chips on ps3s to repair this known issue.
since you are getting beeps and lights this is one of your scenarios. if you get no lights,no beeps then you got a bad Power Supply.
The bip-bip sound means that a necessary input/output device is missing or not working. Go to dell.com/support enter your service tag number download the manual (LINK included) if you have questions of how to search Dell Fourms. Please rate me mysleuth
tre bip lunghi potrebbe essere un problema della tastiera. Nessun bip = difetto di alimentazione, problema alla CPU o alla scheda madre, periferiche in blocco. * Un bip = tutto funziona normalmente. * Due bip = errore POST/CMOS. * Un bip lungo ed uno breve = problema con la scheda madre. * Un bip lungo e due brevi = problema video. * Un bip lungo e tre brevi = problema video. * Tre bip lunghi = errore tastiera. * Lunghi bip ripetuti = errore di memoria. * Brevi bip ripetuti = difetto di alimentazione, problema alla scheda madre. * Continui alti e bassi bip = surriscaldamento CPU. guarda anche questo sito http://www.sergiogandrus.it/index.php/2007/08/22/hardware-significato-dei-bip-beep-del-pc-allavvio/
Its probably bad ram chip. Check that it is seated correctly. Then use another PC to do a google search on beep codes and isolate the actual problem by you PC bios type..
