Home | Toshiba | 55H70 55 in. Rear Projection Television | Lines that gradually get...
Toshiba 55H70 55 in. Rear Projection Television
Problem for Toshiba 55H70 55 in. Rear Projection Television
Lines that gradually get worse on screen
By wildermuth20 on Oct 28, 2009
My tv is a Toshiba 55H71 but this is the closest number i found to it. We are having problems with ours having lines across the screen and the longer it is on the worse it gets. There are only two that run verticle and many that run horizontal. What can we go to fix this?
Popular Solutions for Toshiba 55H70 55 in. Rear
Questions and Unsolved Problems for Toshiba 55H70 55 in. Rear
Do you recommend Toshiba 55H70 55 in. Rear Projection Television?
Answer
Answer
the color on peoples faces is pink. It seems as though the green tint is gone
Answer
the color tint is like pink on peop[les faces and it used to go to the correct color after it was on... (More)
Answer
How do you remove the front panel of our 55" Toshiba for cleaning
Answer
TV was flooded. Already cleaned and ready for re-assembly. We need a circuit diagram to check... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 55H70 55 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
