posted by jlkhj on Jan 02, 2008
I've read that I can take the burrs out to clean this, but I can't figure out how to do it. any assistance would be appreciated!
Solution #1
posted on Jan 08, 2008
You'll need to remove the hopper and grind out all the beans. Then, with the lock tab depressed (if it has one), unscrew the grind adjusting collar out of the body. Once it's out, there are three screws (sometimes only two) holding each burr. Remove screws and separate the burrs. Clean away!
Be very careful putting it back together so that you don't cross-thread the collar into the body. Clean threads can help this.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for La Pavoni Burr Coffee Grinder - Black
Email this problem
Email this problem
Can you Help with these Coffee Grinders problems?
Repair Service
Find Coffee Grinder Repairman Near You:
