Question about Refrigerators
LG refrigerator not cooling
The refrigerator section of our 2 year old frost free LG icebeam grs352gca is not cooling. The temperature cannot be adjusted, the LED's show max cooling but it is not cold. All the LEDs are illuminated except for the first LED. The freezer operates 100%. The unit worked for a couple of days after being switched off, but now has returned to the state described above.
  • ZAPPP Jan 02, 2008
    Hey Wiz; Fan runs with light switch held in ! no frost on refigerator back wall.
  • ZAPPP Jan 03, 2008
    No frost on freezer back wall !
Did we get an answer to this problem?
Posted on Mar 20, 2010
    President:
  • 1,314 Answers
Open your freezer and hold down your light switch see if you hear a fan running next look on the back wall of the freezer see if it has heavy frost and reply to me with answer but dont rate me till were done lol
Posted on Jan 02, 2008
  • robert samples Jan 02, 2008
    how about thee freezer back wall
  • robert samples Jan 03, 2008
    im trying to contact lg to reserch the problem im one of their servicers but i need the specifications i havnt forgotten about you thanks for the in put it really helps
Hi there I have an LG Icebeam Door Cooling fridge that doesnt seem to be working correctly. The fridge is not that cold and the freezer is defrosting on the top section. The light is on and it seems
Find your model # and put it in the search box here: http://www.lg.com/us/support . Once your fridge is showing, there is great troubleshooting info available. Also, armed with the model #, we can actually give you pertinent advice!
Nov 24, 2014 | LG Refrigerators
Could be your thermostat is defect, but even more likely the compressor is not working correct. Perhaps you even lost the cooling fluid. To be sure, please move everything as quick as you can to another fridge and ask a technician to have a look.
Lg service support
Hi Linda, check the back wall of the freezer. If it is covered in frost, it's not running it's defrost cycle and the evaporator are insulated in frost, not allowing the refrigerant to do it's job. Probably a bad defrost thermostat or defrost heater. Hope that helps.
Jul 23, 2017 | Refrigerators
Lg Icebeam Door Cooling fridge/freezer top of freezer not freezing
is the fan not working in it..may be jammed up..we had an old unit that did this all the time.. the door seal was bad allowing house humidity inside and it wpuld frost up so bad the fan got stuck..we eventually bought another used unit..
Jan 20, 2014 | LG Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Older (20 to 25 years old) non-frost free Whirlpool refrigerator is not cooling below 60 degrees. I defrosted it and left it off with doors open in garage for 10 hours. Turned the cooler knob to 4...
Good day,
If it is a conventional refrigerator, there should be a cooling plate on the top back of the wall in the food section.
Assuming the door fits and closes properly, and the light goes out when the door closes, the plate described above should have a frost pattern on it. That is what cools the bottom fresh food section.
If left on for plus 12 hours normal cooling should exist.
If the plate is not frosted, and the machine runs constantly, you have a freon leak with no real practical repair possible.
You could recharge it, but it would be pricey, and just repeat the problem shortly.
Jun 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
LG ICEBEAM GRS512GC. Freezer cooling but fridge not cooling. Just had tech replacee fridge pcb with no sucess... any suggestions? thanks in advance :)
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 23, 2009 | Refrigerators
MAYTAG MZD2766GE SIDE BY SIDE
The freezer on top unit was keeping everything up top nice and cold, but the customer began to notice things in the fresh food section getting a little to warm. When the temperature selectors were adjusted to a colder setting, it seemed to help for a day or two, but then started getting warmer again. Sounding like a defrost problem, I paid this refrigerator a visit with hairdryer in hand, and parts in the van. Frost free refrigerators use a defrost heater to periodically assist with the melting of frost that builds up on the fins of the evaporator located in the freezer section. Frost forms each time the doors are opened to the unit, and the warmer, moist air from outside gets inside and heads toward the cold surface of the evaporator. As the frost continues to collect, the air passages in and around the evaporator start to close up and begin to prevent air circulation by the evaporator fan from the freezer to the fresh food section. As the cycle continues, the temperature in and around the evaporator will be cold, but the fresh food section will get warmer because warm air is not being exchanged with the colder air from above. The defrost sections of most units will consist of the same components. Namely, the heater itself, the bi-metal terminator, and the timer or defrost control. Each one of these components need to work properly for the defrost cycle to properly keep the unit frost free. On this unit, the timer could be advanced to begin a defrost cycle, but there was no current flow to the heater. After checking all connections and doing a quick resistance check of the circuit, I determined the bi-metal terminator had failed open. These bi-metal devices are used to prevent an overheating situation in the freezer section should the heater remain on to long. Once the trip temperature is reached, the bi-metal will open up a set of electrical contacts thus opening the circuit. Then when the unit cools back down to it's reset temperature, the contacts will again close, closing the circuit for the next defrost cycle. Because this bi-metal didn't reset, the circuit remained open and no defrosting took place. After using my trusty hairdryer and warm water squirt bottle to defrost the evaporator, I wired a new defrost terminator in line with the heater. With all the frost removed, the cold air started circulating again, and now everything within the fresh food section stays properly chilled.
Have a manual and can help you. Visit my site and enter your model number and part number in search feature. Click link below
http://servicepartstec.blogspot.com/
saebreezehvac@yahoo.com Thank You, Sea Breeze
Apr 02, 2009 | Maytag MZD2766GES Side by Side...
The fridge section of my LG GRB218JUDA has stopped working and the temperature indicator reads Err FF. Can you help
Side by side and other refrigerators are controlled or cooled by one system. Look to the freezer side for frost buildup on the back wall of the freezer. Frost buildup on the back wall of the freezer stops the air that cools the refrigerator from circulating. Frost on the back wall indicates a problem in the defrost circuit related to the timing device, heaters or defrost thermostat.
Jun 02, 2008 | LG Refrigerators
LG icebeam door cooling
Normally the fans get turned off when you open the door so it does not blow all the cold air out. The fans should only run when the doors are closed. Push in the door switch and see if the fan works then (of course it has to be in the middle of a cooling cycle or the fans still won't run).
Dec 01, 2007 | Refrigerators
Refrigerators Logo
636 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
