Question about Kenmore 24 in. 15992 Built-in Dishwasher
Water doesn't drain after last cycle. - Kenmore 24 in. 15992 Built-in Dishwasher
2 Suggested Answers
6ya staff
SOURCE:
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Water not draing after last cycle
This seems to be a simple blockage within the draining assembly. i would disassemble and take a look at the draining assembly for minor blockage.
Posted on Feb 08, 2009
Maytag clothes washer Model LAT6910AAW. leaks at the last cycle when the rinse water is drained. it may be the drain pump, except it doesn't leak when the wash water is drained (2nd cycle)
If your machine has a tray that you put softener in, softener is the last thing added at rinse time. If it is plugged or has a leaking supply hose, this would cause water paddles and appear to be related to the drain cycle.
Feb 17, 2017 | Maytag Washing Machines
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Doesn't pump out olll the water after a cycle is complete
check drain hose for kinks,,check drain spout for connection blockage..if you cant listen for water going down drain in pump out cycles...remember most dishwasher are intentually not grounded
Aug 29, 2011 | KitchenAid Dishwashers
Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Feb 08, 2009 | Kenmore Dishwashers
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer problem
Inspect the drain hose, see if there is any obstruction.
Try to understand if the machine does not drain at all or if the cycle is not completing , and timer stops before completinc cycle.
If the machine is not draining, then, once you check the drain hose and see no obstruction in there, it can be a faulty drain pump, or a faulty water level switch. If machine instead does not complete the cycle, it is a faulty timer/programmer.
See here for more detailed explanation: It won't drain
Sep 08, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24 in. 15992 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
vince
Israel Pineiro Jr
David Patricia James
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
