Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Comments:
Oct 28, 2009
- Ignitor test procedure
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the unit the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working. If the ignitor did not appear to function and it is the spark type, it may be out of adjustment which generally requires professional service or it may require replacement. If the ignitor is the glow type, you can test it for resistance with a multimeter.
The ignitor has two wires connected to it.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading anywhere between 50 and 600 ohms. If you get a reading of zero or infinity, the ignitor is definitely bad and will need to be replaced.
